Whether you want to connect Cricut Maker 3 to Bluetooth or a USB cable, this step is always recommended when you are up to the Cricut setup! However, this blog will especially focus on how to connect Cricut Maker 3 to computer and mobile devices.
Like many of you, I remember the day I started crafting with my first Cricut Explore Air 2, purchased with my savings. The excitement was real, but so was the confusion. I found myself unable to connect my device to the Cricut machine, a common issue for beginners. However, with the help of the internet, I was able to overcome this challenge and learn the steps to connect my Cricut machine.
Besides, the connection is exactly the same for all devices. Being an expert in crafting, I can teach you to connect your Cricut Maker 3 to your Windows, MacBook, Android, and iOS devices. So, let’s get started now!
Connect Cricut Maker 3 to Bluetooth on Windows 10
When it came to establishing a connection with Windows computers, I was very excited. It is still a cakewalk for me. I can do it within a minute, and so can you! Yes, you can also make this connection in a couple of minutes. Let me show you how.
Here are the superb, simple steps you need to follow to connect Cricut to a PC via Bluetooth:
- Look for a flat surface like a table and place your Cricut within 10 to 15 feet.
- Then, you have to go to the Start menu and navigate to Settings.
- After that, select the Devices option.
- Next, turn on the Bluetooth.
- Also, hit Add Bluetooth or other device.
- Now, click Bluetooth and wait for a couple of seconds until you see your machine in the available list.
- Click on the visible Cricut machine in the list and complete the Bluetooth pairing.
Connect Cricut Maker 3 to Bluetooth on MacBook
Thanks to Cricut, we can use Cricut on our MacBook without any hassle. However, the first step would be the same for Mac as for Windows 10. To learn the steps to connect to Cricut, users need to do the following:
- Turn on the Mac and Cricut cutting machine.
- Next, go to your Mac’s Apple menu and select System Preferences.
- After that, you have to look into the Bluetooth option.
- Now, turn on the Bluetooth.
- And then you must wait until you find a Cricut machine on the available list.
- Once your Mac’s Bluetooth detects the machine, you have to click on it and hit Pair.
Connect Cricut Maker 3 to Bluetooth on Android
Android devices, including Samsung, Google Pixel, LG, Motorola, and One Plus, are compatible with Cricut machines. Hence, if you want to connect Cricut Maker 3 to your Android devices via Bluetooth, you need to go through the following steps:
- Go to your Android smartphone, then search for the Settings section on it.
- After that, you will need to move to the Bluetooth option.
- Now, you have to turn on the Bluetooth.
- Next, you have to wait and visit until your device finds your nearby Cricut model.
- Once you see the Cricut machine, click on it to pair it.
- Finally, you have connected the Cricut cutting machine to Bluetooth.
Connect Cricut Maker 3 to Bluetooth on iPhone/iPad
Are you using an iPhone or iPad? You can also connect your Cricut to Bluetooth on these devices without hassle. To connect, you have to follow the steps below:
- Head to the phone’s Settings.
- When you finally reach the settings, you need to go for the Bluetooth option.
- Then, enable the toggle button to turn on the Bluetooth.
- After that, you will have to wait sometime to see whether your iPhone or iPad detects any Cricut devices that are available.
- When your Cricut machine is finally detected, you have to select that and proceed to pair.
- Now, move forward by simply clicking on the Pair.
FAQs
Question 1: Why is my Cricut Maker 3 not connecting to my Android?
Answer: Whenever you encounter this issue on your Android, you will need to check for the following points:
- Verify Bluetooth: Ensure Bluetooth is turned on and that Cricut and Android phones are within the range of 10 to 15 feet.
- Check for physical obstructions: Make sure there is no interference between your device and Cricut. To reduce the interference in the signal, you can disable the nearby Bluetooth devices.
- Unpair and repair: Unpair your machine and then repair it to fix the issue.
Question 2: Can I connect Cricut Maker 3 to a PC via a USB cable?
Answer: Yes, you can! You can connect Cricut to your computer using a USB cable. To connect, you have to go along with the following steps:
- Plug in and power on your Cricut product.
- Then, you have to plug one end of the USB cord into the Cricut’s USB port and the other end into the computer’s port.
Question 3: What do I need to connect my Cricut Maker 3 to PC?
Answer: In order to connect a Cricut machine to your Windows computer, you will need things as follows:
- A USB cable or Bluetooth connection
- A Windows desktop system requirement in the section below:
- Windows 8 or later
- Intel Core series or equivalent AMD processor
- 4GB of RAM
- The new version of Firefox, Chrome, or MS Edge
- 50MB of free disk space
- Screen resolution of at least 1024px x 768px
