Seeed Fusion PCB Assembly Service offers one-stop prototyping for PCB manufacture, PCB assembly and as a result they produce superior quality PCBs and Fast Turnkey PCBA from 7 working days. When you prototype with Seeed Fusion, they can definitely provide Free DFA and Free functional tests for you!
![](https://cdn.hackaday.io/images/4706191523595288042.jpg)
More details About The PCB::
![](https://cdn.hackaday.io/images/5230601523265590274.png)
![](https://cdn.hackaday.io/images/235401523265590697.png)
Test run the PCB and with all the components
More details about the PCB in High Res, you can check tha PDF file attached below
Faceplate and ardubuino PCB plan
![](https://cdn.hackaday.io/images/5553901523595122260.png)
can used it as midi device
