Work has begun on putting together a demonstration rail for the Aquariumatic.
The rail setup consists of two rails on some triangular mounts (3D printed, sourced from Thingiverse). the Front rail consists of the units (Pi Server, Arduino-based controller, and eventually two NodeMCU based modules to simulate extra Controller units) and the back rail consisting of the Power distribution, power regulation (both 5v and 12v) and 4 rail mountable UK plug sockets for attaching the aquarium hardware such as heaters, lights and pumps (controller by the arduino controller).
Hopefully it will be wired up and running in the next week or two :-)
![](https://cdn.hackaday.io/images/7182531515801026355.jpg)
![](https://cdn.hackaday.io/images/7418021515801073856.jpg)
![](https://cdn.hackaday.io/images/8619791515801113230.jpg)
![](https://cdn.hackaday.io/images/589631515801157500.jpg)
