differential-scope-probe
Differential voltage probe
0 followers
Have you ever worked on some low power micro controller project and needed to measure current in the micro-amp range?
Have you ever wanted to measure current transients on your micro controller project?
Then this project is for you.
Application
References
Other interesting links
  • DIY 1GHz* Active Probe for Under 20$
    • interesting idea to use pogo pins for probing.  An improvement mount one of the needles under an angle.  So it's possible to probe 0603, 0805 and 1206 packages.
    • FET to be replaced by CF739 for better performance.
  • Component selection
    Christoph Tack09/18/2019 at 20:17 0 comments
    DC/DC converter
    Powering the AD8129
    The original plan was to use a 5V to +12/-12V converter.  The problem with this high supply voltage is that schottkey diodes need to be added to protect the differential inputs.  These will lead to extra leakage and thus measurement errors especially when measuring small currents.
    The solution is to use an MDD02L-09 or equivalent power supply.  This limits the common mode range to +7V/-7V.
    Differential amplifier
    ADA4622-1
    Ideally suited as transimpedance amplifier.
    Maximum output current when used as transimpedance amplifier?
    AD4927-1
    • 2.3GHz -3dB bandwidth
    AD8129
    • 200MHz -3dB bandwidth
    • +10V/-10V CM-range
    • +0.5/-0.5 DM-range
    • 250nA input bias current -> not suited for measuring µA-range currents
    • Gain = +10 (can be adjusted)
    AD8479
    • 130kHz -3dB bandwidth
    • +/- 600V CM-range
    • 500kohm Zin(CM), 2Mohm Zin(DM)
    • Gain = +1
  • Housing
    Christoph Tack09/09/2019 at 18:25 0 comments
    Miniature Plastic USB Enclosures (1551USB Series)
    • DWG files from manufacturer can be converted to DXF with https://cloudconvert.com/dwg-to-dxf.
    • After cleanup with LibreCAD and a check for the correct scale, the file can be imported in EasyEDA.
View all 2 project logs
