UPDATE 01/12/2018 6:31:PM
Tactical flashlight scan @ 2ms CCD 8-Bit (TCD1304DG) detector circuit test:
![](https://cdn.hackaday.io/images/2184741515800027394.png)
A better 1st mirror alignment and a 2nd 150mW laser line test:
![](https://cdn.hackaday.io/images/9407631512286530741.png)
The plot above has a FWHM value of 1.005nm resolution.
Fixed the 1st mirror position, I have much better resolution now :)
![](https://cdn.hackaday.io/images/7379701512174458910.png)
![](https://cdn.hackaday.io/images/6001601512174510002.png)
Another test scan today using my Aries 150mW green laser and a 0.1mm slit width @ 3ms integration time:
A little bit of clipping can be seen even though I had the variable polarizing lens at 75% still got a resolution factor of 2nm :)
![](https://cdn.hackaday.io/images/3571441512166409126.png)
![](https://cdn.hackaday.io/images/3282581512166455748.png)
New test scans using the 8-Bit CCD detector (TCD1304DG)
![](https://cdn.hackaday.io/images/2484401512110408591.png)
![](https://cdn.hackaday.io/images/4450081512110376342.png)
![](https://cdn.hackaday.io/images/6247291512110504894.png)
Final version of the Motor Control Targeting Interface unit for the diffraction grating turret control system:
Excel chart data:
![](https://cdn.hackaday.io/images/7263481511131713454.png)
New CCD scans using a 32mm achromatic coated lens @ the 1st collimation mirror and a compact fluorescent lamp, below is the raw data of various scans:
![](https://cdn.hackaday.io/images/4491661511127833203.png)
Below is the processed data of my CFL lamp:
![](https://cdn.hackaday.io/images/9467021511127878658.png)
and finally, the FWHM data from the above spectrum:
![](https://cdn.hackaday.io/images/6267051511127920011.png)
A calibrated Solux lamp spectrum (mine,) 4700K/50W/12vdc/1.2A/0.10mm slit width
Turret @ zero position (baseline) 0.00 nm/ Integration time: 150ms
2400ln/mm diffraction grating:
![](https://cdn.hackaday.io/images/3669751510878078847.png)
![](https://cdn.hackaday.io/images/1478781510878109685.png)
7 Dark Count scans I did to determine which integration time is the most ideal and it appears to be 50ms, 15ms and 10ms:
![](https://cdn.hackaday.io/images/5209051510322942776.png)
CCD detector Allmon & Haffner v1.1 is done.
![](https://cdn.hackaday.io/images/5877011510250543281.jpg)
![](https://cdn.hackaday.io/images/6485621510250567756.png)
![](https://cdn.hackaday.io/images/9257941510250914311.png)
-Testing Platform
PLX-DAQ v2.11 Dual Trace Transfer to Excel
New 8-Bit TCD1304 CCD detector driver board
New schematic
8-Bit Main SCH 1
8-Bit Sheet 2
Cost analysis comparing Raman Spectrometers and Lasers from StellerNet Inc. to the DAV5 V3.01 3D printable Raman Spectrometer:
DAV5 V3.01 Raman Spectrometer uses an Aries 532nm 150mW CW/DPSS Green Laser
Cost - $ 199.99 US
The DAV5 V3.01 3D Printable Raman Spectrometer
DAV5 V3.01 Raman Spectrometer - $ 657.35 US
This is great! That too with 80% 3d printed objects!
Cool stuff sir!
