If you wanted to get started with bit slice CPUs in the 1970s, you needed an AMD 2900 Evaluation and Training Board. I snagged on in great condition and put it through its paces.
Details
Read the Hackaday post (pending) and watch the video for all the information you need.
Scanned manual (with two typos). Figure 7 (pg 3-15) has an incorrect "next address" table. Use Figure 3 on pg 3-5 instead. Or use the better reference here. Example 7 on page 6-20 also has wrong next address fields.
Adobe Portable Document Format -
3.88 MB -
03/22/2024 at 14:53
