Capabilities
  1. Build to withstand a nuke - I mean, not a direct hit obviously - would probably need a bigger case for that. But it is hardened against the effects of an Electromagnetic Pulse which is a side effect of a nuclear detonation. When the case is closed, it forms a complete conductive shell around the interior electronics. The interior of the case has a double layer of faraday fabric (held in place with rivets and conductive tape). The stock Pelican O-ring was replaced with a conductive gasket and the O-Ring slot was lined with faraday tape, and all potential weak spots were painted over with a water based Nickel conductive paint. Then, the interior was lined with Flex Seal (yeah that guy), to create a rubberized insulation layer, so the shielding isn’t shorted. Lastly, ferrite chokes were placed on many of the wires inside the case as a last line of defense.
  2. Offline Information Library - Hundreds of GB of information saved to the hard drive (Wikipedia, Medical Cooking recipes, Ted Talks, WikiHow, etc.)  saved and served locally via Kiwix
  3. Offline Navigation and Positioning- World map tiles downloaded and working locally with the embedded GPS antenna
  4. Signals Intelligence - prebuild SDR apps (just swap antennas)
    1. Aircraft tracking via ADSB & RTLSDR
    2. Receive HighRes NOAA weather information and data via GOES geostationary satellites
    3. AM/FM radio receiver
    4. Programmable Transmit capability with HackRF
  5. Offgrid Long Distance Communication - plug in HF antenna and use Digital modes like JS8Call to communicate cross country (potentially internationally) without relying on Cell infrastructure or even satellites.
  6. Battery & Power - Internal (12Ah) LiFePo4 battery much safer and longer lasting than Li Ion. 3 switchable Power domains to minimize power draw based on use case. Typical lasts >14 hours with no recharge.
  7. Radiation detection - detection of radiation levels via Nukalert sensor
  8. Modest compute and extensibility - 2x Raspberry Pi 4Bs with 2x USB 3.0 ports
*Technical Specs moved to components. its a working list im actively updating*
System Design
At a glance - Raspberry Pi v4 as the client, Raspberry Pi v5 as the server, and Teensy 4.1 acting as a microcontroller
ClientPi:
ServerPi:
Teensy 4.1:
Software Services (air-gapped)
Controller*
Navigation
Wiki
ADSB
HackRF
Weather**
HF**
* = work in progress
** = have an idea, haven't started
***=want to but not today, tomorrow, or next day
There is so much more to cover, I feel like I'm barely scratching the surface. I will be making periodic updates as i find time and organize all the pictures, documents, etc - but I appreciate your patience – I don't want to just feed my coffee-stained napkin notes into chatGPT and submit whatever comes out ;)
In the meantime feel free to reach out about technical Qs, suggestions, or ideas!
