broken gadget
(DISCLAIMER: This is not an area I'm very strong in)
According to this random website I found online:http://www.s-manuals.com/smd/2n
The component in question (given the form factor looks like SOT-323) should be 2N7002W
http://www.s-manuals.com/pdf/datasheet/2/n/2n7002w_fairchild.pdf
The actual 2n4 on that list is not the right entry, by the looks of things.
Джонатан, спасибо за вашу помощь, я постараюсь сделать аналогичную замену. Только когда я измерял размеры, более подходит для SOT-23.
TheThirdMan
Raunaq Bose
Rifqi Abdillah
Paul Stoffregen
Yes, delete it Cancel
You are about to report the project "identify an element", please tell us the reason.
