Quick-to-use ESP32 development device
The wiring we'll aim at:
To test:
If planning to use other GPIOs, it's easier to solder on the DM-102 before attaching the ESP module but can be done later. I strongly recommend soldering any required extra GPIOs also to the board as you won't get very robust connections directly to the ESP's crown "pins". A male / female header or DuPont connector can be hot glued to the other side for IO.
