Slow-ish Movie Player
Because I'm not patient enough for one frame per hour.
Loved this https://hackaday.com/2018/12/30/the-very-slow-movie-player-does-it-with-e-ink/
Saw this https://hackaday.com/2020/08/23/e-paper-display-shows-movies-very-very-slowly/
Finally inspired by this https://hackaday.io/project/175630-slowmovie-cinema-on-a-27-epaper-display
I'm using the larger and higher resolution 7.8" Waveshare e-paper screen, which is not supported by the Waveshare EPD library used in the current version of Tom Whitwell's github repo at https://github.com/TomWhitwell/SlowMovie I have mixed Greg's Python in with it.
Here is the GitHub repo mashup of https://github.com/TomWhitwell/SlowMovie and https://github.com/GregDMeyer/IT8951
I decided on a default frame rate of one frame per minute and rendering every 4th frame, so it will progress a bit faster.
Test
  • Next movie
    Richard Hogben06/09/2021 at 20:37 0 comments
    I seek the Grail.
  • Good morning!
    Richard Hogben05/11/2021 at 15:42 0 comments
    Have you met Eye-gor ?
  • Remembering to sleep E-paper displays
    Richard Hogben04/28/2021 at 22:26 0 comments
    When I added the IT8951 code to the SlowMovie Python I commented out this line, with the intention of adding it back...
    #epd.sleep()
    What happened? The display was not entering deep sleep which appears to have caused an early failure :(
    New sleep line:
    display.epd.sleep()
    Now that the display sleeps correctly, I required the "init" line which I had also removed...
    #epd.init()
     Adding the "run" command seems to work:
    display.epd.run()
    If anyone knows technically why sleep is required, feel free to comment below! I'm assuming this has to do with the constant charging of the particles that separately create the black and white image, and a constant charge must wear them out?
  • Cooling!
    Richard Hogben04/26/2021 at 14:47 4 comments
    I reversed the direction of the fan I installed to blow over the Pi rather than draw from it. So far has been over 48 hours and no freezing.
    Exterior fan
    Air exit
    The Pi
    Kubrick ?
  • Not cooling?
    Richard Hogben04/20/2021 at 14:49 1 comment
    I added the heat sinks to most of the larger silicon and now have a fan drawing air over them but have still experienced the screen failing to update.
    Pressing the reset button on the Waveshare hat puts the screen back into an operating state. The Pi script is still running, so on the next image push the screen updates like normal.
    It's hard to believe the issue is heat anymore because it's not getting much beyond warm, if that.
  • Cooling :(
    Richard Hogben04/16/2021 at 16:29 0 comments
    So it turns out the Raspberry Pi Waveshare hat does not like being stuck in a box :)
    After some hours the Pi script is still running but the Waveshare hat seems to have stopped updating the screen.
    If I leave the back open and some room around the controller it is stable. I'll need to add some passive cooling to the Pi and vent the rear door of the frame.
  • Finished Frame
    Richard Hogben04/14/2021 at 20:50 0 comments
    The frame is deep enough to house the Raspberry Pi and stand on its own. There is a door that sits flush with the backing and lets me run a power cable out the back.
    There is enough room for a fairly large battery, and I'm sure it's possible to put the Pi to sleep and only wake up to run the job and update the screen. Then I could ditch the power adapter.
    Can you guess the movie?
View all 7 project logs
View all 3 instructions
j2r2jones wrote 02/20/2022 at 18:48 point
Hi Richard, nicely done! I was hoping you could elaborate on "When I added the IT8951 code to the SlowMovie Python". I have the IT8951 hack working from Greg, but I can't seem to get the SlowMovie script to output anything still.
Richard Hogben wrote 05/23/2023 at 21:54 point
Hey sorry didn't see this for a year I guess :) Were you able to run the Python tests? - python test/integration/test.py
Did you start from my repo or the others?
Richard Hogben wrote 12/21/2021 at 20:26 point
Thanks
Alana Richard wrote 05/04/2021 at 13:30 point
wow great, nice looking project.
Alberto wrote 04/29/2021 at 10:45 point
Hi:
Nice project. I forked one from Tom Whitwell SlowMovie. With the intent or learning some python while adding a web server to monitor/configure the running SlowMovie server https://github.com/aturiel/SlowMovie
Richard Hogben wrote 04/29/2021 at 16:49 point
Hey that web server interface looks great!
Mike Szczys wrote 04/20/2021 at 16:19 point
Wow, that is a beautiful display! Like 2.6 megapixels? What are your thoughts on image quality?
Where you have it installed makes sense to have a power cord. I'd be interested though to see how long it would run under battery power.
Richard Hogben wrote 04/20/2021 at 16:22 point
It looks decent without dithering if you bump the contrast. It has a little horizontal banding sometimes, like it looks streaky? Not sure if that's from the controller or just how these displays are.
Mike Szczys wrote 04/26/2021 at 21:22 point
I wonder if that's some ghosting due to the LUTs not being well tuned on the sample hardware. The ePaper manufacturers are known for keeping their secrets to themselves and publishing less than spectacular sample code. I have a 5.83" panel I'm working with that gets horizontal banding when driving it with my own code but not if using the stock controller (it's a digital price tag).
Richard Hogben wrote 04/28/2021 at 22:02 point
So I'm pretty sure the issue was when I changed the controller code over I commented out the original sleep line and forgot to add the new command. Looks like it being on with voltage applied for a week killed it.
mikko.pihlajamaki wrote 04/16/2021 at 05:39 point
The Shining?
Richard Hogben wrote 04/16/2021 at 14:47 point
Got it!
Dan Maloney wrote 04/15/2021 at 19:52 point
Nice looking project, and I like the idea of not-quite-as-slow-as-the-other-slow-motion-movie-players approach.
But I give up -- what's the movie?
hayday wrote 05/14/2024 at 13:44 point
That would be Young Frankenstein, 1974?
