a QT Py / XIAO Compatible board based around the WCH CH23V203
We finally found the time to assemble the 3 prototypes.
Hans did a quick test and got everything working as intended. Even the tiny 1x1mm WS2812 LED is working!
Hooray, the prototype PCBs and stencil arrived. All parts are on the way so its just a matter of putting all the components on there and start the testing!
View all 2 project logs
sxpert
sirmylesavery
The Big One
Bob Coggeshall
Yes, delete it Cancel
You are about to report the project "LANA TNY", please tell us the reason.
