Esparagus HiFi MediaLink
ESP32 based streaming upgrade for your audio gear
Public Chat
Starting from
$45.00
andrey-malyshenko has 721 orders / 23reviews
Ships from Poland
The ESP32-based device is designed to modernize legacy audio equipment from the pre-internet era by incorporating cutting-edge internet streaming capabilities. This standalone device seamlessly connects to your speaker system, offering an effortless upgrade to enable streaming services and enhance your audio experience.
It runs Spotify-Connect, Apple Air play, Logitech Media Server as well as acts as Bluetooth speaker. It can be used to build multi-room audio systems. It can run your software as well, as it is fully open-source and open-hardware.
This project is based on the HiFi version of the ESP32 Audio Dock, in fact it shares a lot with it. But it adds a few important extras.
Most noticeably it adds an aluminum case which adds a much more finished look, compared to the bare pcb module. I had a custom back panel that exposes the most important board interfaces.
- USB-C port for power, flashing and debugging
- Line level audio output. You can drive headphones with it, as well as connect to your stereo system, like a traditional pre-internet amplifier.
- Wi-Fi antenna connector. (As you may imagine perception is not so good inside alu case)
- 5V Relay output driver controlled by GPIO (if you wish to switch your external amp off, when device goes to sleep).
It uses an off-the-shelf ESP32-WROVER module that includes a PSRAM chip, which is basically mandatory for internet streaming projects.
It is designed primarily to be used with the squeezelite-esp32 software, which is a brilliant way to enter streaming era using low-power device, like ESP32
I'm planning to add a transparent front panel, therefore the OLED screen and RGB led are in WIP state, but it is possible to connect and use them.
Adobe Portable Document Format - 557.02 kB - 01/15/2024 at 16:10
Preview
Download
Adobe Portable Document Format - 168.68 kB - 01/15/2024 at 16:10
Preview
Download
Zip Archive - 110.04 kB - 01/15/2024 at 16:10
Download
  • Crowd Supply campaign is in pre-launch
    andriy.malyshenko02/15/2024 at 11:42 0 comments
    Hey everyone.
    I passed the formalities necessary to actually start a Crowd Supply campaign to support production of the Esparagus series boards.
    If you're a hobbyist maker it is actually very hard to produce these small projects in small volumes, because of fundamental costs of initial development. When you know in advance what kind of volumes you should expect to produce, it is much easier to build up an adequate price for the unit.
    Public campaigns also help to understand if a product is finally ready for a launch, as adding improvements and new features is a never-ending effort. At some point you have to say "Although it's not perfect, it's sufficiently near".
    I invite everyone interested to subscribe to campaign updates, as in coming weeks I will need to work hard to finalize the design and prepare for the production run, which will strongly depend on the community interest.
View project log
martymcbro wrote 03/31/2024 at 18:37 point
This streamer looks really promising. I am looking forward to buy it as soon as you add the transparent panel for the display as stated above. Maybe it even has room for a SH1122 display?
Did you also think about adding an IR receiver and/or a rotary encoder to the front or do you prefer not to offer local control options?
Regards
ctjameson wrote 01/05/2024 at 00:56 point
I can't wait for you to have this readily available. I've done a deep dive on LMS and the assorted squeeze platers lately and having an "off the shelf" solution to recommend to friends is amazing. It's so hard to ask them to buy a development board without a case or any finishing. I would love a similar product with the Louder ESP32 Components as well as a line/headphone out. that would honestly make the best and coolest little desktop streamer box.
