Our Final Prototype and Presentation
Our final angel prototype and base was completed, and we were able to showcase it in our final presentation and IMA Show.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
We were given the privilege to present our final prototype to our class mates and other professionals. The final prototype included a larger base that hides the portable charger used to power the PCB (microbit). We ended up using the microbit instead of the PCB due to its built in microphone and compatibility with the code. When the volume level is high the light will dim and when there is no sound the light will rise. Later on, professor Rudy assisted us in printing a new model that was more compact and detailed however due to time constraints we did not have time to implement it into the final design.
