A shoulder mounted soft robotics air puppet that uses beat detection and forward/reverse fans to dance the night away.
I spray painted an air puppet envelope with neon black light reactive paint and then stenciled ghosts on top. Worked out great.
Remove all straps and padding. Remove the shoulder plastic flaps. Cut out pleather to cover exterior shoulder pad surfaces. Glue pleather to stripped down shoulder pads (I use upholstery spray contact cement).
Once extraneous parts of the football shoulder pads have been removed and black pleather has been attached its time to start creating a shoulder mounted dance platform for our green friend.
Bolt the fans to the hinged wooden platforms - 4 fans on each shoulder. The fans should have at least 1.5" clearance underneath for airflow. After bolt holes have been drilled in the platform (when we know the positions of the fans) cut out a 1" diameter hole under each fan for additional airflow.
