Hello to all my readers; welcome back to my other blog. Please remember that I introduced you to the latest member of the Explore series in the last blog. Now, it's time to discuss how you can connect Cricut Explore Air 2 via Bluetooth. You all will agree that Cricut keeps launching new Cricut machines. Among all those models, I prefer the Cricut Explore Air 2 Setup as it gives physical form to my DIY dreams and creates new ideas.
Ever since I added this Cricut machine to my craft room, I have been creating new projects for personal and professional use. Apart from cutting materials, the Explore Air 2 has an in-built Bluetooth feature. You can connect the Cricut machine wirelessly to Windows, Mac, iOS & Android devices. This tutorial will help you understand the method of connecting this Cricut Explore model to computers and mobile devices.
Connect Cricut Explore Air 2 via Bluetooth to Desktop
As mentioned in the earlier section of this tutorial, the Explore Air 2 easily connects to PCs wirelessly. Don't leave the golden chance of learning the process following which you smoothly connect both devices via Bluetooth:
For Windows
By studying this area of this blog, you will be able to collect details on connecting this craft plotter to the Windows system.
- Initiate the process by switching on your cutting machine and keeping 10-15 feet from your computer.
- Now, tap the Start menu, then select Settings > Devices option.
- If your Bluetooth is on, click the Add Bluetooth or other device option.
- Following this, tap the Bluetooth and stand by till your computer detects this Cricut machine.
- Afterward, a pop-up window will display a list on your computer screen.
- From the list, click the Cricut Explore Air 2 mentioned in the list.
- You can successfully connect Cricut Explore Air 2 via Bluetooth on Windows through these steps.
Are you curious to learn how to connect this Cricut model to your Mac wirelessly? Then, you are most welcome to refer to the following part of the blog.
For Mac
Are you looking for directions to connect this Cricut machine setup to your computer? If yes! Then you need to pay attention to the following instructions:
- Inaugurate the method by repeating step 1, which you did on a Windows computer.
- Then, open the Apple menu > select System Preferences > tick the Bluetooth icon.
- Now, select Turn Bluetooth On on the left-hand and stand by till the scanning is in progress.
- Further, select your Cricut machine from the device's list to continue the process.
- In the end, you will learn that the connection process has been completed successfully.
Connect Cricut Explore Air 2 via Bluetooth to Mobile Devices
You must be aware of the connection process if you complete most of your work from your mobile device. The Cricut new product setup supports desktop computers like this, so you can efficiently operate it on your Android or iOS device.
For iOS (iPad, iPhone)
Educate yourself by coming across the guidelines that will give you a chance to learn about wirelessly connecting the Explore Air 2 machine to your iOS smartphone:
- Ensure your machine is on to connect Cricut Explore Air 2 via Bluetooth to an iOS device.
- After verifying that, place both devices at a distance of 10-15 ft from each other.
- Then, open the Settings tab and click the Bluetooth option.
- Start looking for the Cricut Explore Air 2 inside the Other Devices section.
- After finding it, select it and stand by for a few minutes till the connection process is on the way.
- You deserve a pat on the back for successfully connecting this cutting machine to your iOS device.
For Android
Subsequently, take a look at the below steps as it will be sharing with you the steps for connecting your Android phone to the Cricut Explore Air 2:
- You must begin this process by repeating the iOS device step 1.
- After that, scroll down your Android device home screen and hold on to the Bluetooth icon.
- Now, enable Bluetooth and keep calm till your Android device detects the machine.
- At this time of the process, click the Cricut Explore Air 2 from the Available Devices section.
- Finally, both of your devices will successfully connect and are all set for cutting materials.
Connecting this Cricut Explore model to PCs and mobile devices will make it much simpler to create thousands of custom-made projects from this craft plotter.
Frequently Asked Questions
Can I Connect My Cricut Explore Air 2 Using a USB Cord?
You can connect your Cricut Explore Air 2 to devices using a USB cord. No doubt, you have to follow the below-said steps:
- Please turn on your respective devices and keep them close to each other.
- Now, unbox the USB cord that comes with your cutting machine.
- After that, take one side of the cord and put it inside the machine's USB port.
- Next, insert the cable's other end into your device's USB port.
- Then, the machine power button gets enabled, indicating that the connection has been made successfully.
How Can I Setup My Cricut Explore Air 2 on Computer?
To setup your Explore Air 2 on your computer, go through the following steps:
- Begin the process by switching on your machine & plugging it into the wall socket.
- Now connect your devices via USB cable or Bluetooth (as per your choice).
- Next, download the Cricut Design Space app on your system & sign in to the account.
- After doing that, go through the on-screen instructions for setting up your devices.
- Finally, you will be invited to a test cut when the setup is finished.
Why Is My Cricut Explore Air 2 Not Connecting to Bluetooth?
There are different reasons why you might be facing errors while connecting the Explore Air 2 to Bluetooth. The reasons are as follows:
- Incompatible device
- Your device operating system isn't updated
- Other devices already connected
- Your device's Bluetooth is off
For more information: Cricut.com setup mac
