Hey, do you want to learn how to connect Cricut to Bluetooth? Don’t worry—I’ve got your back! When I was 14 years old, I used to make many paper crafts using tools like scissors, blades, and other stationery items. Using these tools was often dangerous, as they could cut my fingers, and there was always a potential risk.
But as I grew up and started living on my own, the first thing I bought was a Cricut machine. Yes, I have spent years trying different tools and machines to craft things that I always wanted to make. As a crafting expert, I have now started uploading videos to YouTube. There, I teach my audience about Cricut, like how to use it, the connection and setup process, and get started with DIY projects.
In this blog, I will show you how to connect Cricut to a computer and mobile via Bluetooth. So, are you ready to learn? If so, let’s get started!
Why Do You Need to Connect My Cricut Machine?
When I first got my Cricut, I was in a dilemma about how to connect Cricut to Bluetooth. But there was also another option, like connecting it to a Mac via USB cable. This is why I was in a dilemma. So, I decided to choose an easy method, such as a USB cable, and then, after some days, I moved to a Bluetooth connection.
So, now, why do we need to connect it to any device? We need to connect Cricut to our computer or phone because we have to control our Cricut using any device.
Also, we need to create an intricate design on Cricut software and send it to a Cricut machine. Hence, all these tasks cannot be performed without connecting the Cricut to the device.
How to Connect Cricut to Bluetooth on Mac?
When I begin connecting my Cricut to Bluetooth, I always start by placing it on a flat surface. The flat surface is needed because when you cut the material or load it into it, you will need to load it straight into it. Hence, I chose the flat surface. Besides, I kept my Cricut within 10-15 feet of my Mac. Ensure you are placing your Cricut or device within a reasonable distance of each other. Otherwise, it will cause trouble during the connection.
Here’s how to connect Cricut to Mac via Bluetooth:
- Power your Cricut machine by plugging all its power cables into the wall outlet.
- Now, you need to turn on the Mac computer.
- On your Mac system, you have to go to the Apple menu.
- There, select System Preferences.
- As you enter the screen of system preference, you will see a plethora of apps.
- Amongst these apps, you have to look for the Bluetooth option and click on it.
- Now, you need to make sure the Bluetooth is on. If it is not, you have to turn it on.
- After that, wait and see if it detects your Cricut model for pairing.
- Once it appears, simply click on the Pair button to pair.
- Finally, your Cricut is connected to your macOS desktop.
How to Connect Cricut to Bluetooth on iOS?
I also have an iOS device, which I use when I have to work on a small design. It is portable enough to carry and control the Cricut remotely and hassle-free. So, if you are looking for the steps to connect your Cricut to your iOS device, follow the steps below.
Here’s how to connect Cricut to an iOS device via Bluetooth:
- On your iOS device, you will need to find the Settings app.
- Then, launch the settings on your phone.
- After that, you have to look for the Bluetooth option.
- Once you have found the Bluetooth option, turn on the Bluetooth by simply clicking on the toggle button.
- Now, you have to wait for some time and see if your device detects any nearby Cricut machines.
- After some time, you may see the Cricut machine on your phone.
- Simply click on the device that appears on the phone and proceed to pair it.
- Then, click on the Pair button.
- Now, you have finally added your Cricut to your iOS smartphone.
- You can easily proceed further to setup your Cricut hassle-free.
By the end, you might have understood how to connect Cricut to Bluetooth on devices like Mac or iOS. The stepwise instructions given will surely help you connect your Cricut to your device in no time.
FAQs
Question 1: Which macOS can I connect to my Cricut?
Answer: According to Cricut’s official website, users with macOS 11 or higher. Besides, there are hardware requirements that you should check before connecting Cricut to your Mac. Below are the requirements you need to ensure on your Mac for your Cricut:
- Operating System - macOS 11 or later
- CPU - 1.83 GHz
- RAM - Minimum 4 GB
- Display - Minimum 1024px x 768px screen resolution
- A USB or Bluetooth is required
- Disk - 2 GB
Question 2: What do I need to connect Cricut to Bluetooth?
Answer: To connect your Cricut to Bluetooth, you will need a Cricut machine and a computer with Bluetooth features. However, if you want to connect it via a USB cord, you need a USB cable. Make sure your Cricut has a USB port. You can also connect your Cricut to your phone. For this, Bluetooth and a Cricut machine are needed, and that’s it!
Question 3: how to connect my Cricut to Android?
Answer: Follow the steps given below to connect your Cricut to an Android phone:
- On an Android phone, go to your Settings.
- Once you reach settings, move to the Bluetooth option.
- Then, you have to turn on your Bluetooth.
- Wait and visit until your device finds your nearby Cricut machine.
- Once it appears, select it to pair it.
Visit: install cricut design space app www.cricut.com setup login cricut create connect to computer cricut.com/setup
