The ultimate dual OPL3 MIDI syntesizer with touch screen
Just a short project update this time to announce that after more than year of struggling with bad hardware designs, mistakes and frustrations the new OPL Studio is now available in my Tindie store for everyone!
The new units improve upon the existing OPL Studio design. I've taken into account the feedback and wishes that I've received from many users over time as well as my own wished to create the ultimate OPL2 MIDI synthesizer!
The 'old' kits will also remain available for everyone who already owns an OPL3 Duo or OPL2 Audio Board and wants to expand its capabilities, or for those who want to customize OPL Studio to their own liking.
Right now I'm putting together the first production units of the new OPL Studio. It's the final step and it can sometimes be frustrating since I'm extremely happy that finally units are working well and I'm almost able to share them with the rest of the world, but also it's where I find all the little problems that I want to fix before putting the new all-in-one OPL Studios in my Tindie store.
Now is the time when I figure out what is the best way to assemble each unit, what to look out for during assembly, what to test, and how to fix the inevitable mistaks that I'm going to make during assembly.
Some parts turn out to be easier than expected. The ZIF connector for the LCD with all of its tiny pins was the most nerve wracking component at first. But after surprisingly few times I got the hang of soldering it and now I no longer break a sweat.
On the other hand, for the enclosure I've found lots of little mistakes that I needed to fix. I ended up redesigning most of the enclusure over the past couple of weeks. This resulted in an enclosure that's simpler to 3D print and wich is much sturdier than the design I had before. The LCD bezel was the final pice of the enclosure puzzle that I needed to solve, as it was too easy to come loose. It now clamps into the LCD mount so it won't come loose so easilly anymore.
For now I'm putting together a small stock pile of units and awaiting a few more components that I ordered too few of, but then after a very, very long time the new all-in-one OPL Studio will be available!
With the new hardware also comes new software. The OPL Studio software v2.0 is the first release to support the all-in-one as well as the existing kit versions of OPL Studio. No changes are needed, the software detects the hardware during start up and fully supports both models.
Support for the new hardware is not the only new thing in the 2.0 software. In this release all of the OPL3 synthesizer code has been rewritten. It no longer relies on my Arduino OPL2 library and that makes it much more flexible toward the future.
This was a huge undertaking that I really underestimated. It has taken me several months and from a feature perspective the 2.0 software may look like nothing new has been added, but it lays the ground work for some very exciting new things coming soon!The new software is already available on GitHub. The OPL Studio website I will update next week.
The hardware for OPL Studio with integrated OPL3 Duo! is ready!!! It has taken many months with lots of frustrations and times where I just wanted to give up, but now it's finally here :)
I've put together a quick video to show the first images of the all in one OPL Studio in action. It's playing a simple MIDI tune running an inbetween version of the old and upcoming re-write of the synthesizer code. The audio is a direct capture from the line out. You can hear some exagerated vibratos that I had hardcoded while experimenting with the new synth code, it does sound nice on this tune I think.
The enclosure is also almost ready, so in a couple of weeks the new OPL Studio will be finally available from my Tindie shop!
Finally I have good news to report on the all-in-one OPL Studio!
This design is like a night and day difference compared to previous prototypes. The audio is clear, the line out has a higher output level and the speaker out has a much, much lower noise floor. There is no more noise on the line out and on the speaker out there is only very slight noise from the LCD if you're listening through headphones and the OPLs are silent.
There is light at the end of this very long tunnel now!
Is it all good? No! Of course I did find more mistakes. The biggest one being the LCD connector. At one point during the design I had rotated the footprint, but I fell into 'a trap for young players' and I forgot to also reverse the order of the pins! So the LCD was dead. After realizing this I was a bit hesitant about fixing it, because it was tricky enough to solder the connector the first time and desoldering it and soldering it back after rotating was a good challenge! Also because there was no room. I had to solder the connector back at an angle and let it rest on some resistors and capacitors. To my surprise I managed to do it!
The LCD showed some signs of life, but still no clear image. It only showed a garbled mess of gray pixels. So I was sure that I messed up when soldering the connector. But to my surprise, when I added a connector for one of the old LCD modules, it was showing the same mess of pixels. This confused me and took me a while to figure out. It turned out to be the reset signal. On the kit design I had not used it, but for the all-in-ones I intended to use it. Turns out that I had not given the LCD controller enough time to properly reset. Problem solved after a simple software fix. Even the touch screen worked on the first try.
The brightness is still a bit of an issue, because it doesn't work as it did on the old design. The screen is very dim, so that's still something I need to fix.
There are other small things that need fixing. Transistor footprints that are not quite right, the MIDI status LED being too bright, the 3D printed LCD mount that needs some tweaking.
All small thing that I will be working on in the next two weeks and get another few PCB prototypes made to check what should be the production version of OPL Studio.
All the parts to assemble the fist new All-In-One prototype have arrived and I have now put together the first board!
The LCD connector was especially difficult and exciting cause of the teeny tiny pins and I wanted to be careful not to melt the plastic while soldering the part with hot air. There were a few bridges that I managed to fix with the soldering iron, some flux and carefully dabbing the excess solder with some desoldering braid. I'm happy with the result and it seems that at least there are no shorts.
Of course I did make some mistakes when I ordered the components... :)
I haven't yet tested the board. I need to make some software changes to accomodate the different pinouts on this board. This is what I'll do during the course of this week and hopefully the prototype works as expected!
While I was waiting for the new PCBs and components I continued working on the MIDI and OPL controllers in the software. The audio part has been completely reworked to allow for exciting new features such as pseudo 4-OP instrument patches, patch effects and MIDI control mapping.
Right now the MIDI control mapping is finished, except for the UI. You can now map any incoming MIDI CC to a synthesizer control. For example map MIDI CC 54 to a software vibrato, software tremolo or patch parameter such as operator output level.
Next up will be to implement support for pseudo 4-OP patches...
Now the sequencer has been updated and after a few day where I added additiona file support to the media player it's time to get back to the hardware of OPL Studio!
The media player now supports DOSBox raw OPL (*.DRO), id Music Files (*.IMF) and Video Game Music (*.VGM)
Before my christmas holiday I spend a lot of time breadboarding parts of a new all-in-one design and experimenting with a previous prototype that has now become a Frankenstein setup with many loose wires, replaced components and failed experiments. The goal was to fix the issues that existed with the previous prototypes. Whether this is now the case I'll not comment about. I have been disappointed a few times before after getting excited about new PCBs.
So another round of prototypes is now going to get manufactured where I made some drastic changes that I left out of previous prototypes:
While I wait for the new PCBs I will continue working on the next major update of the software. The code that handles MIDI and controls the OPL3 chips will be refactored to allow for some cool new tricks:
The new sequencer is nearing completion. All functionality has been implemented and many bugs have already been fixed. The newest additions since the last log are:
Drum sequences are still not using the new sequencer and I will definitely leave that until after the new software update. I now just want to release this thing after a few more days of testing to capture as many bugs as I can.
Next to the sequencer update there will be a fun little secret hidden in the new software ;)
I have some good news on the all in one units this time. When using the line out the audio is now fine. No more excessive noise from the different components. The amplifier to the speaker out is still a problem, but I think I also have that mostly covered now. I've been working on a different amplifier design using a different chip that as far as I've been able to test sounds promising. I have a little test amplifier breakout board on the way to test my new design before I integrate it into the main PCB.
For the LCD module I also have some new plans. So far I've been using complete modules for the LCD and touch panel that also include an SD card socket. The problem I'm having with these modules is that too often they are of questionable quality where some have brightness issues, some of them have misaligned touch screen panels, others have issues with adhesion of the different layers of the LCD and so on. This means that for every OPL Studio I've been shipping so far I've been hand picking the LCD modules to make sure they function correctly. This also means that I've been rejecting far too many modules (around 25%) and then I'm not even counting all modules that arrive broken due to aweful packaging done by vendors. Anyway, to get a better grip on LCD quality I will change to building the modules myself or rather I will use the loose LCD + touch panels that connect to the main PCB using a ribbon cable and I will build the interface myself. I have a few panels on the way to test this out.
Finally the enclosure will also get an update, though it will keep the same dimensions and overall look as the current units.
Time for another sequencer update!
I had a little break in between to attend the 2023 Eindhoven Maker Fair with the OPL Studio and some other projects of mine. It was a lot of fun to see and talk to everyone there and have lots of people and especially kids play around with all the synths I brought! Lots of good energy to continue work, so there has been a lot of progress over the last couple of weeks.
The sequencer is now at a point where it's fully functional and includes all the panels that allow you to edit all sequence details.
In the previous log I wasn't sure yet how I could facifitate editing sequence details such as note properties, volume, modulation, etc. I was thinking to add a little panel with tabs below the piano roll, but since most of the screen was already taken this would be way too small. Still sticking with the tabs seemed like the only viable option, although still the screen is too small since I need 6 tabs and this wouldn't leave any room to show any labels on the tabs. This meant that it was time to expand the UI with a new component: a tabs ribbon! The ribbon now allows me to scroll through a list of tabs if there are too many to fit on screen.
The 'Sequence' tab is the main tab of the sequencer where you create your sequences by recording MIDI or using the drag and drop piano roll and where you do all your basic editing. The other tabs go into more details of the sequence and allow you to tweak all the tiny details. Something the old sequencer really was lacking!
The first tab shows the note details. It shows a graph of the full sequence and all of the notes. Using the spinners and rotary controls you can now navigate through the sequence note by note and change parameters such as note velocity, panning and start and duration up to MIDI tick level. Quantization is also done in this tab, plus there is a handy feature to equalize the velocity and / or panning of all sequence notes. By clicking the equalize button a dialog will open that allows you to set a default velocity and panning. Handy if your fingers don't always hit the keys with the right pressure.
The next tabs allow you to change volume level, panning, pitch and modulation. They all function in a similar way. Again the sequence graph is there to show you the parameter values over time, with the notes of the sequence in the background (in dark grey). In these panels you can tweak existing events that you may have recorded from MIDI, you can add new events and of course delete them. A handy reature is to interpolate between the values of two events when you're adding them manually.
For now the sequencer has all the basic functions that I want it to have. Some things that are still missing are more controls to add, delete, copy and paste notes, to transpose the sequence and to configure the MIDI channel. This will be added in the coming weeks as well as more improvements and streamlining of the code while I work and play around with the sequencer. Whether or not I'll also replace the current drum sequencer with this new one in the same release is something I'm not yet sure of. Eventually I will, but it depends a bit on how much memory I will have left on the Teensy and on how much effort it takes to finalize the sequencer.
It's been quiet here for a while regarding updates, but I think that today I have a nice one.
Ever since I had the melody sequencer in OPL Studio I never really liked it. It's ok for just the basic stuff, but it's a pain to really get serious about editing your sequences, because it only shows you if one or more notes are active on a step. You can't easilly change existing notes, let alone change any other properties such as modulation, panning, etc after recording.
This is now going to change. I've had the idea to implement a piano roll style editor for a long time and finally now is the time to show the progress I'm making with it.
The new sequencer is a more conventional piano roll style editor that you may be familiar with from other MIDI editing software. You can add notes to a sequence by simply drawing them onto the piano roll. This is also a welcome improvement for when you don't have a MIDI device to record from, but still want to play with the sequencer. You can drag new notes up and down to set their pitch and left and right to change their length. As you drag the notes around they will play.
Existing notes can be dragged across the piano roll to change pitch and location. You can grab the end point of notes to change the start and end points. Or long press to delete individual notes from your sequence. While dragging the notes around, the piano roll will automatically scroll.
The little piano on the left hand side of the view shows you the range of the musical scale where you're editing and you can press the keys to get a note preview.
The piano roll has a green playhead to indicate the current playback position. As you play the sequence the piano roll will start to scroll to show you the notes that are being played. Scrolling can be disabled by disabling the scroll lock on the bottom right of the view.
When you are in recording mode the playhead will turn red and show you where the next note will be recorded in the sequence. All existing recording functionality still exists in the new sequencer: direct MIDI recording, step recording and the ability to set up a trigger to start recording as soon as a note on event occurs.
It took quite a lot of code to get this all working, but it was well worth it I think! The piano roll makes the sequencer much more user friendly and powerful. But, we're not done yet... Moving notes around is just one thing, but as the tabs at the bottom of the screen may be giving away already, there will also be options for more detailed editing. Changing note velocities, volume, panning, pitch, modulation etc.
The detailed editing is something I haven't fully figured out yet how to make it work in the UI on this tiny screen. It also leaves no room for the 'menu' buttons that I have on some of the other app modules to, for instance, copy & paste. I'm sure I'll figure it out as I go...
Below you can see a demo of the sequencer in action.
Despite all the hardware troubles with the all in one boards I'm not forgetting about the software with some nice updates coming up!
The drum sequencer has always been kind of left out when it comes to recording and MIDI functionality. You could create a drum sequence by tapping on the sequence buttons in the app, but not record from the MIDI inputs.
This will finally change! The drum sequencer will now listen to MIDI channel 10 for drum notes to play. You can also record a drum sequence from MIDI, where the sequencer will assign the various drum sounds to one of 8 tracks depending on what drum sound is played and which tracks are available. You make a recording by clicking the record button to go into recording mode and clicking play. While working on this feature I found that the way in which a triggered recording is started (recording starts when the first MIDI note is received) was a bit counter intuitive. You would click the record button to enable a recording and then long press the play button to go into trigger mode... That will now be changed to doing a long press on the record button to go into triggered recording mode for both the melody and the drum sequencers. Of course our friend the metronome will also make an appearance in the drum sequencer.
Something that I didn't mention yet is that the drum sequencer also received a randomizer function some time ago. When you click the Random button the current track of your sequence will get a random pattern. Great for experimenting!
A second improvement that is coming up is about how you can select instrument patches. Throughout the UI there are these spinners where you need to step through your patches one by one to select the one you want. Not very user friendly! To improve this there will be an instrument selection window that shows you a list of all available patches (melodic or drum) that you can scroll through to look up and select the patch you want. When you select a patch from the list it will go into preview mode, so you can immediatley hear a different instrument playing and you can select another one right away if you don't like the one you selected. You open the instrument selection by double clicking on the instrument name in the spinner. Of course the old way of stepping through the instrument one by one will also still work.
From the mixer you can now also change the instrument patch of each channel (except for channel 10) by clicking on the instrument name.
Lastly, I've started to work on an on-screen keyboard that will help you in one of the sequencers or the patch editor when you don't have a MIDI input connected. The little keyboard can play individual notes by tapping the keys on screen, but it can also do pitch sides by dragging the stylus left or right and modulation by dragging up and down when a note is playing.
The keyboard can be opened on its own as well from the accessories panel. In that case you will get some additional controls to select an instrument patch, adjust volume and panning and maybe some more.
For the all in one boards I've now narrowed the problem down to the amplifier. The line out with some additional caps sounds crystal clear! The speaker out however is still unusable. I'm thinking it's the ground plane or the lack of a good ground plane... I need to make a video of it and reach out to see if there are some audio gurus who can help.
This thing is incredibly well thought out and beautiful! Thanks a lot for making this.
I just ordered one of the current boxes with the external opl3 chips. I wonder If I could mod the chip so that I can make the box have multiple outs?
I have read that one chip has in theory four output channels. And it's a dual so there should be 8 possible outs for this, correct?
Would it be possible to tinker with the hardware a bit and then assign the channels in the software so that half the audio channels go to the second channel? Or to have the drum channels on a separate out?
Would be bloody useful to be able to mix that separately or record multi tracks. Thanks in advance for any help or pointers! Really looking forward to the opl studio :))
Unfortunately it's not possible to mod OPL Studio this way. With the 2 OPL3 chips you can indeed have 8 differen output channels, but the OPL3 board and OPL Studio lack support for this. It would require two additional DACs, filters and maybe some more changes to the hardware as well as implementing all the routing of the outputs in the software to make this possible.
If you're willing to sacrifice panning then you can use the OPL3's hard panning to separate the channels over outputs A and B which are used for the left / right audio channels.
Wow! That is very cool! I'm searching for OPL3 standalone device. Yours is even more interesting!
This is great, really love the dos look to the ui. Whenever boards are available I'll take a set, bare is fine. Can source and assemble myself, take my money please.
I would like to place a preorder for a preorder. Lol
This project is awesome. I just bought one of your OPL3 Duo. Would it be possible to replicate this build? If you need beta tester or maybe help. I studied music recording than Multimedia at university and worked on app/interface development. I also own a professional recording studio and can produce real good demo. Im getting back into Arduino coding after a long break. Really like where your going with all your implementation. I currently jam a lot sequencing all the channel of a Roland MT-32 like you do with your build. Keep up the great work.
Sorry for the late reply. Thanks for your interest! I want to have the project ready for an early beta in a month or two. By then some feedback on the features, workflows and connecting it to an existing setup will be really appreciated. I'll reach out to you around that time to let you know :)
This is a great product. Very interesting.
I don't have much knowledge so let me ask you a question.
I like old games from the time of Windows 95.
Their BGMs are MIDI and are made for Sound Blaster 16.
I am interested in OPL Studio since it has OPL3, just like Sound Blaster 16.
With OPL Studio, is it possible to play those games' BGMs on my Windows 10 PC with the same sound as the originals?
Those games will not run on my Windows 10 PC, but I would be happy if I could play the MIDI files of the BGMs on a real chip.
