The Reflow946 is a Bluetooth LE temperature controller for the 946C electronic hot plate. Using this controller, a reflow profile can be programmed from your web browser using the Web Bluetooth API. You can use preset profiles (e.g. for lead-free or leaded soldering) or create a custom profile for a perfect cheese fondue.
