Just the catalogue page, manual, and circuit diagrams.
No firmware, but there is example code in the manual.
I have no board, so I can't read the PAL chips, but they're probably based on the SC88T and the PIO stuff should be simple to recreate.
The SC88PIO is an 80188 CPU, with up to 256Kbyte EPROM and up to 256Kbyte SRAM, with battery back and write protection on-board. The main applications are for fast low-cost target systems, or as the main CPU in large systems. The SC88PIO also integrates 28 buffered parallel IO lines on the 50-way Arcom standard Signal Conditioning Bus connector.
The SC88PIO has two serial IO channels, two counter-timers, DMA, and interrupt handling. Eight lines are output (24mA sink), eight lines are input and eight are-bit-bidirectional (with 16mA sink capability), two are counter/timer inputs and two are counter/timer outputs. Therefore low cost target systems can be built with just a SC88PIO and a Signal Conditioning Bus board.
Built as an enhancement of the low-cost SC88T, the SC88PIO is software-compatible with the SC88T. This allows use of exactly the same code and development tools as used on the SC88T. The interrupt, DMA and bus interface can be configured to be identical to the SC88T. The SC88PIO has extended temperature range and low-power CMOS options.
