Inside the ThermoNIX
A project log for ThermoNIX Multi-Channel Thermometer
Combining a Nixie milivoltmeter and an arbitrary number of manually switched LM35 temperature sensors.
keri-szafirKeri Szafir 05/06/2024 at 16:040 Comments
Not a real deal build log, but after I built it, it turned out I jumbled the ranges: gains didn't correspond to comma positions, so I had to redo the range switch. It was an opportunity to take a look inside and make a video.
