Integrated HUB - Ethernet, USB, RS232
Swiss Army Switch - Ethernet Switch, USB HUB, USB-Ethernet and USB-RS232 Adatper
I frequently use a (1) USB HUB, (2) ethernet switch, (3) USB to ethernet adapter, and (4) USB to RS232 adapter for R&D at work. My goal to integrate these 4 dongles into a single PCBA. Bonus points if I don't need external power... early power budget seems possible but unlikely.
====== Project Status ======
Schematic -------------------- ( ✓ )
PCB Layout ------------------ ( ✓ )
Documentation ------------- ( In Progress )
Order + Assemble --------- ( ✓ )
LAB: Sparkup ---------------- (  ✓ )
LAB: SI Analysis ------------- ( Pending )
LAB: Power Analysis ------ ( Pending )
Derisk Capacitive XFRM - ( Pending )
IC-Plus-IP175G.pdf
Ethernet Switch Datasheet
Adobe Portable Document Format - 1.15 MB - 05/16/2024 at 05:21
Preview
Download
  • Cheap Chip Woes - Ethernet Switch
    Jesse Farrell4 天前 0 comments
    After getting most of the peripherals figured out in the design, I started delving deeper into the datasheets for the core components. I should be doing this earlier in my design, but this is a hobby project dang-it, I think I’m allotted a handful of poor decisions.
    Most of the parts had reasonably clear documentation, except for the cheap ethernet switch I selected early in the design. I’ve added the datasheet to the documents if you want to play along. Among the general lack of reference designs, I found the following…
    • PLLVCC (Pin7) – What do I connect it to!!!
      The datasheet doesn’t specify where this pin should be connected. Is the rail generated internal or do I need to power it externally? Is it especially sensitive, and maybe needs some ferrites, or just a local decoupling capacitor? If you search the entire datasheet for “PLLVCC” you’ll find two instances. One is the pin diagram, the other is the pin description, “Power of PLL circuit”.
      Resolution – For the first prototype I’ll add a jumper to power PLLVCC either from 3V3, 1V0, or leave floating w/ decoupling.
    • VREG_LDO (Pin41) – Min Capacitance?
      I’d really like it if the datasheet gave any sort of comment regarding output capacitance for the internally generated regulator. What is required for stability at least, or even a comment saying there IS no minimum….
      Resolution – Adding 0603 1uF Cout. Larger package allows for tweaks later if needed.
    • EEPROM – What Address?
      This one is pretty depressing, and would have been exceptionally easy to add correct. The device uses an external I2C EEPROM that can store configs that are loaded at startup. However, the address of this EEPROM isn’t specified.
      Resolution – Select EEPROM with configurable address. Sniff bus when prototype board arrives.
    • Magnetics Ect
      This might be caused by my inexperience in networking related designs, but I’d really like to see some baseic design recommendations for the magnetics. My understanding is that the topology of the PHY can have several downstream affects for the termination / center tap on the transformer. Lacking this info, I’ll design in what seems most widely used.
  • Early Design
    Jesse Farrell05/09/2024 at 05:00 0 comments
    Overview
    I’ve been thinking about making an ethernet switch for awhile and finally found a good reason to make my own. At work I often have to use 4 tools for high level debug;
    • Ethernet Switch
    • USB HUB – Lab Computers long since ran out of USB
    • USB to Ethernet Adapter
    • USB to RS232 Adapter – For debug
    It’s a real pain to have to scavenge all these adapters from around the lab, and the assortment of dongles takes up valuable bench space. The goal of this project is to Frankenstein these 4 devices into a single design.
    FYI for anyone reading. I’m not very familiar with the networking stack, so if I sound a bit uncertain about the topic it’s because I am… (part of the reason I wanted to do a project related to networking. Time to do some learning!)
    General Block Diagram
    I’m using a “keep it simple stupid” philosophy for this design. As such the block diagram looks eerily similar to the 4-tool amalgamation I just mentioned. Something that might be interesting is the PHY-PHY connection b/w the USB to ethernet adapter and the switch. I don’t need any isolation there, so no need for expensive magnetics.
    Now that I have the rough functionality worked out, I need to see what components are actually out there (and at what price!). As much as possible I’d like the design to be (a) cheap and (b) simple. I’ve been in firmware hell for another project, so I’ve had my fill of SW/FW debug for a while.
    Exploration - Ethernet Switch
    There really isn’t much on Digikey. At least not within my budget. Filtering for an in stock / non-marketplace / Ethernet switch, leaves me with several Microchip parts all >$5 at low quantity (see for yourself -> Digikey Search).
    Let’s see what China has to offer. LCSC conveniently has an entire page dedicated to “Ethernet Switches” (here). Filtering on cheapest in stock part lands me on IC Plus IP175G. Can’t say I’ve heard of this manufacturer but at ~$1 it has my attention.
    I’ve read through the datasheet and it seems like it fits the bill for my project. Its got an integrated MAC (thank God), decent buffers (I think?), and some more advanced features. Its recommended application is “5 port 10/100 Dumb swith” and “4TX+1FX Dumb Switcn”. The switch must be extra dumb!
    I did some hunting for reference design, but its very bleak. There’s no official reference design, nor is there any open-source example. The best I could find was this product (SwitchBlox Nano) uses the chip, so clearly its
    Exploration – USB to Eth / HUB
    Digikey doesn’t seem to have ANY cheap options for a USB to ethernet adapter. In this case it seems like I can’t really avoid an expensive part, and I’m not sure I’d want to anyhow. I’d like a more widely available part with good support, so I don’t have to fight with any windows driver wackiness.
    I ended up going with the Microchip LAN951x series. Its an integrated USB to ethernet adapter coupled with a USB HUB. Its only USB 2.0, but for my use case I don’t need heaps of bandwidth. I haven’t done a deep dive of the datasheet yet, but it looks like I could easily use any of the 3 variants; LAN9512 / LAN9513 / LAN9514. The last digit reflects the number of USB ports present on the HUB. I’ll design in LAN9514 and DNP parts as needed to support the cheaper variants.
    When searching for reference designs, it looks like this part is even used on the Raspberry Pi 3! That’s handy.
    Exploration – USB to RS232
    Another adapter that will be potential for windows driver wackiness. Similar to the previous adapter, I’d like to avoid the bottom of the barrel options. I suspect I’m overthinking the driver setup headaches, but I’ve never worked on a board that needs any kind of windows support so…. Rule number 1 “keep it simple stupid”.
    My first thought for RS232 support was FTDI, I think most designers have used or at least heard of this manufacturer, and I figured it would be dead...
View all 2 project logs
