Block Diagram
Calculations
The duplexer is obtained putting together two separated filters:
  • high pass for 433 MHz
  • low pass for 144 MHz
i calculated the two filters separately using lc-filter-design-tool/.
See below the calculation for the 432 MHz high pass filter: note that I set the cutoff frequency at 400 MHz
and the 144 MHz low pass filter. Please note I set a 150 MHz cutoff.
Schematic and LTSpice simulation
Assembly
I used a small case 74 x 74 x 22 (H) mm
The 56 nH, 91 nH and 82 nH inductances are obtained with 4 turns of 1 mm enameled copper wire on a 6 mm diameter.
Their different values are set with different length (The higher the length the lower the inductance)
The 15 nH are 1 single turn of 1 mm enameled copper wire on a 4 mm diameter.
Results
144 MHz side
  • insertion loss at 144 MHz = -0.5 dB
  • attenuation at 432 MHz = - 52 dB
432 MHz side
  • insertion loss at 432 MHz = -0.4 dB
  • attenuation at 144 MHz = - 45 dB
