RTC modules: RTC PCF8563
04/16/2024 at 16:14 • 0 commentsModule with RTC, battery and EEPROM
PSU modules: Multiple PSU modules in one device
04/04/2024 at 19:09 • 0 commentsThis schematic diagram explains how multiple PSU modules are connected in one device
PSU modules: PSU AC
04/04/2024 at 19:05 • 0 commentsThis module allows you to power your device with AC power source.
A wide range of input voltages allows this module to be used with 115V or 230V power outlets.
PSU modules: PSU DC
04/04/2024 at 18:53 • 0 commentsThis module allows you to power your device using a common DC power source.
The input voltage range is from 7 to 40 V.
IO modules: DIO16
03/25/2024 at 10:37 • 0 commentsDIO16 module is a simple 16-channel GPIO expander on I2C bus.
Logic levels - 3.3V
LED status indicators for each input/output
ESD protection
Up to 16 such modules can be connected to one device with a total number of GPIOs - 256 pcs -
IO modules: DO8
03/20/2024 at 13:52 • 0 commentsThe DO8 module adds 8 transistor outputs to the device (up to 500 mA per output).
It is perfect for controlling relays.
Up to 16 such modules can be connected to one device with a total of 128 outputs! -
IO modules: DI8-ISO
03/16/2024 at 21:58 • 0 commentsThis module adds 8 digital inputs with optical coupling to the device. Up to 16 such modules can be installed in one device with a total of 128 inputs!
Interface modules: RS232
03/14/2024 at 19:58 • 0 commentsThis module adds a RS232 port to the devices.
Galvanic isolation or jumpers can be soldered into the module (then the module has no isolation).
Interface modules: RS485
03/12/2024 at 20:13 • 0 commentsThis module adds a RS485 port to the devices.
Interface modules: CAN
03/08/2024 at 22:53 • 0 commentsThis module adds a CAN interface to the devices.
CAN-FD is not supported.
