Raspberry Pi Phone-Your Own Phone That Can Call and Text Under $70
3mf - 98.00 kB - 10/04/2022 at 21:11 |
3mf - 43.77 kB - 10/04/2022 at 21:11 |
Connect the pins on the raspberry pi to the screen. To test the connection, plug in the raspberry pi. The screen should glow white. Take the SD card, and install it with the latest version of Rasbian. Attach the USB microphone and adapter.
Attach raspberry pi to monitor, and go through the setup guide. Go into a terminal and type
sudo rm -rf LCD-show git clone https://github.com/goodtft/LCD-show.git chmod -R 755 LCD-show cd LCD-show/ sudo ./LCD-show 90
Wait a few minutes until your monitor turns off and your screen turns on. Open another terminal and type
sudo nano /usr/bin/toggle-keyboard.sh
than inside the file type
#!/bin/bash PID="$(pidof matchbox-keyboard)" if [ "$PID" != "" ]; then kill $PID else matchbox-keyboard & fi
Press ctrl+x, then y, then enter to save.
Type
sudo chmod +x /usr/bin/toggle-keyboard.sh
Once that is done type
sudo nano /usr/share/raspi-ui-overrides/applications/toggle-keyboard.desktop.
Inside the file type
[Desktop Entry]
Name=Toggle Virtual Keyboard
Comment=Toggle Virtual Keyboard
Exec=/usr/bin/toggle-keyboard.sh
Type=Application
Categories=Panel;Utility;MB
X-MB-INPUT-MECHANISM=True
Then press ctrl+x, then y, then enter to save.
Run cp /etc/xdg/lxpanel/LXDE-pi/panels/panel /home/pi/.config/lxpanel/LXDE-pi/panels/panel than
nano /home/pi/.config/lxpanel/LXDE-pi/panels/panel. Go to the bottom and type
Plugin {
type=launchbar
Config {
Button {
id=toggle-keyboard.desktop
sudo reboot. When the screen loads again, on the taskbar you should see a keyboard. This is for texting.
On your computer type www.poptox.com. This is a google website that is a dialer. Subscribe for any plan you want, from $10 to $50. You will get unlimited calls. Type this in the raspberry pi browser and star it so you don't have to type to get it. Go to Vonage to get a free trail texting. Star that too. Anything you want to add like games, star. If you want to text, open google, click the Vonage star, and click the keyboard in the taskbar.
phones and tablets soon going to be sold at http://asherdundas.wixsite.com/picreate
If you want a better PiPhone, I am making a thin android version which you can find here.
https://hackaday.io/project/189830-piphone-version-2-putting-it-in-your-iphone
Thanks for the 11 thousand views!
