A Cricut mat can become dirty after several uses. Sometimes, they may start losing their stickiness. I have been crafting for the last 5 years, and I have experienced the same situation. However, you can overcome this issue efficiently and save time. All you need to do is learn how to clean your Cricut mat. Yes, you heard it right. Once you have an idea about the Cricut cutting mat cleaning ways, you can select one and start using your mat like before.
The Cricut mat becomes dirty with the regular cleaning process, and thus, it becomes necessary to clean it and make it sticky again. I often see Cricut users looking for methods to clean their cutting mats. Hence, I decided to write a helpful blog post on it. Here, I will share the three easy ways with you all guys.
Let’s dive into the post.
Method 1: Using Baby Wipes
Are you looking for how to clean Cricut mat with baby wipes? Well, in this section we will get to know mat cleaning with baby wipes.
- Simply move to your crafting room and grab some baby wipes.
- If you don’t have baby wipes, first purchase them.
- Grab baby wipes in your hand.
- Now, move to the one corner of your mat.
- Go with circular emotions and wipe the mat
- Next, make sure that you have cleaned the entire mat.
- Don’t apply too much pressure while cleaning the mat.
- Finally, let your Cricut cutting mat dry for around 3 to 5 minutes.
While learning how to clean your Cricut mat using this method, you need to be a bit careful. It is a good way to go with light pressure. You might need 2 to 3 wipes to clean the mat. When you follow this you will find that your mat has become clean and sticky again.
Method 2: With LA’s Totally Awesome Cleaner
LA’s Totally Awesome cleaner is a great way of cleaning the mat and making it ready for use. But the thing is how you will use it. Get into the below-mentioned steps and follow them carefully.
- Initiate by reading all the instructions mentioned in the cleaner.
- Spray an even coat of the cleaner on your cutting mat.
- Now, allow the cleaner to sit on the mat for something around 3 to 5 minutes.
- Next, you will need to grab the scraper tool.
- Hold the scraper and use a light hand.
- Otherwise, you will damage the mat by removing its adhesive.
- If you didn’t get the result the first time, go back and try the second time.
- Don’t try to remove all the tiny particles from the mat.
- When you rinse the mat, they will automatically come out.
- After that, use warm water to rinse off the mat.
- Lastly, keep the mat out and allow it to dry for approximately 20 minutes.
With these super easy steps, you can clean your Cricut mat and use it like before. The method is easy to follow and as you have seen, it takes very less time.
Important Note: While spraying make sure that you are not under spraying. If you under spray the cleaner, the mat will not clean.
Method 3: Using Dawn Dishwashing Liquid
Another method you can go for cleaning your mat is using the dawn dishwashing liquid. This way you have to learn how to clean your Cricut mat. Here is a step-by-step method to show you the process.
- First, move to your Cricut cutting mat.
- Once you are there, grab the dawn dishwashing liquid.
- Now, put in some dawn dish soap on your mat.
- In the next step, allow the mat to sit for approximately 3 to 5 minutes.
- Thereafter, hold your cutting mat.
- Run water into it.
- Then, use your fingers to rub away the tiny unwanted particles.
- You can use a paper towel for this purpose.
- We recommend not using a sponge or other similar things.
- The adhesive from your mat will rinse off.
- Next, go over your Cricut cutting mat.
- Use a dry paper towel to dry your mat.
This is how easily you can clean your mat and use it to make the craft you want. Out of the above-mentioned methods, you can select one and execute it to clean your mat thoroughly.
Conclusion
Cricut mats get dirty after further use, and thus, they need to be cleaned properly. With a proper cleaning technique, they can be put into use again, and thus, Cricut users can save a little money, too. Learn how to clean your Cricut mat and then start using them for cutting. There are three major ways of cleaning mats. These are using baby wipes (gentle cleaning method) or LA’s totally awesome cleaner or dawn dishwashing liquid.
Frequently Asked Questions
Can You Suggest Some Ways to Keep My Mats Clean?
Yes, here are some easy-to-follow suggestions that will help you keep your mats clean. More than that, it helps keep the adhesive of the mat long, too.
- Most often, you use a lint roller/scraper to clean your Cricut cutting mat.
- Remember to replace the plastic protector sheet.
- When you proceed with cutting, don’t forget to use the right mat as per the material.
Do I Need to Clean My Cricut Mat Regularly?
No, you don’t need to clean your mat on a regular basis. Cleaning cutting mats depends on how much you use them. Found the Cricut mat not sticky after cleaning? If you craft regularly and use your mat most often, it is a good idea to clean your mats more often. However, if you craft one or two times a week, there is no need to clean the mat regularly.
How Can I Clean a Cricut Cutting Mat Using Dish Soap?
Do you want to clean your mat right now? If yes, you can use dish soap. Here are the methods explaining how you can proceed. Thus, learn how to clean your Cricut mat below.
- Grab a scraper tool and use it to remove unwanted material from your mat.
- Then, lay down your mat on a flat surface.
- Use a dish brush (soft) and scrub the mat’s surface.
- In the last step, let your cutting mat dry.
For more information visit: Cricut.com setup mac
Source: How to Clean Your Cricut Mat
