Cricut Explore Air 2 is a magnificent machine if you want to start crafting and cutting your materials. If you are looking to buy a new Cricut machine and wondering what you should go for, I would suggest you buy an Explore Air 2 machine. The Cricut Explore Air 2 setup is one of the first things that you are going to need to learn. In this blog, I will cover everything you will need to know, like what’s in the box, complete machine setup procedure, and many more. So, without any further delay, let’s get started now!
What Comes in the Cricut Explore Air 2 Box?
Before you start setting up your machine, you have to open the box and check for the tools and the supplies. When you open the box, you will see the following things:
- Welcome kit
- A Quick Guide Book
- Cricut Explore Air 2
- Power Adapter (To connect your machine to electricity.)
- USB cable (To connect the Explore Air 2 machine to your device.)
- Fine-point blade and blade housing (It is pre-installed)
- Accessory adapter & pen
- Cricut LightGrip mat (12x12)
- Sample materials for your first cutting
Cricut Explore Air 2 Setup on Your Operating System
You have to follow the steps below to setup your Cricut cutting machine on your computer or smartphone.
- To setup the machine, the first thing you have to do is open the box.
- Check if all the required tools are there or not. Usually, tools are not missing, but in some cases, a few tools may be missing. If any tool is missing, you can contact your seller, and they will provide it.
- Once all the tools are there, you have to plug your machine into electricity using a Power Adapter.
- After that, connect Explore Air 2 with your computer or phone device using a USB cable, or you can also connect it via Bluetooth.
- Then, download the Cricut Design Space app on your device from cricut.com/setup.
- If you already have it, check if it is the latest version or not. If it does not update the software, it works smoothly.
- Once you connect the machine to your device, sign in to your Cricut ID.
- If you don’t already have one, you will need to create a new account.
Download Cricut Design Space on Your Device
You have to download the Cricut Design app on your phone or computer in the process of the Cricut Explore Air 2 setup. You can download it from the Internet. Full details are given below.
- If you are using a desktop, you have to go to the browser and look for the app on cricut.com/setup.
- In case you are using mobile, open the Play Store app and search for the Cricut Design Space software.
- When you see the app, click on Download, and it will start downloading the app.
- The software will be saved in your system as downloaded files.
- Open the saved files and click on the app before starting the process of installation.
- Now, you have to click on the Install icon of the app.
- Open the Cricut app to log in, and you are ready to start crafting.
How to Create a Cricut Account on a Device?
Before starting to cut on your Cricut cutting machine, logging into your Cricut account is necessary. You may log in if you have already made an account. But if you do not have an account, there is nothing to worry about. You can create an account by following these steps.
- Open your phone or computer and go to the Internet browser.
- In the browser, go to cricut.com/setup and download the Design Space app by clicking on the link.
- Tap on Create a Cricut ID and wait for your details to be filled in.
- There, you will see a series of columns where you have to fill in the details. In the first column, you have to provide your email address.
- In the next column, fill in the password. Make sure you put a password that is not difficult for you to remember. So that the next time you sign in, you won’t have any problem.
- In the following column, you have to fill in your full name.
- You are almost ready with a new Cricut account. Just follow the directions that the app asks for.
- Finish setting up the account and you are done.
Conclusion
So, if you were worried about your Cricut Explore Air 2 setup, I am sure now all of them have gone away. These are the four simple steps that you can follow to setup your Explore Air 2 machine with your device. You have to check for the items and then setup the machine. After the machine is setup, download and install the Design Space app and log into the Cricut account. If you don’t have a Cricut account, create one so that you will be ready for your first cut.
FAQs
What software do I need for my Cricut Explore Air 2?
The software or app that you need to use for the Cricut Explore Air 2 is Cricut Design Space. This app is available on the Internet for free. You can open any web browser and go to cricut.com/setup. Next, download the Cricut software and log in to your account. But if you want a better experience and access to its complete features, go for the Cricut Access plan.
How to connect Cricut Explore Air 2 via Bluetooth?
Connecting your Cricut cutting machine to your device through Bluetooth is very easy. First, you have to plug in the machine and turn it on. Then, go to your operating device’s settings and open Bluetooth settings. If Bluetooth is off, you should turn it on. Now, search for your Cricut model. Once it pops up, tap on your machine and select connecting. It will be connected.
What is the connectivity issue my Cricut Explore Air 2 is having?
If your Explore Air 2 is having connectivity issues, check if your machine is on or not. When it is on, make sure it is not more than 10 to 15 meters away. In that case, your device will not be able to locate the machine. If you are trying to connect it using a USB cable, maybe your cable is old and has a straining problem. In that case, you will need to buy a new cable.
