Cricut machines are the favorite DIY tool for new crafting enthusiasts. Also, these Cricut machines are improving day by day and becoming more advanced than ever before. When machines are constantly updating, why stay behind? I’m a Cricut expert, and here in this guide, I’ll be sharing with you the process of connecting your Cricut machine to your computer so that you can utilize each and every feature of the machine right from your operating system. So, let’s start learning how to connect your Cricut to your computer.
In this post, I will include every aspect of the Cricut setup for your convenience. You’ll learn the procedure for both Windows and Mac to setup a Cricut machine. Once you setup your machine, you’ll be ready to create your desired projects seamlessly.
Minimum System Requirements to Download Cricut Design Space
As you know, setting up your Cricut machine needs the installation of Cricut Design Space software, you’ll have to meet the minimum system requirements to install it on your compatible device. So, here I’m listing all the necessary requirements to get started with your Cricut.
For Windows
- Operating system- Windows 10 or the latest
- RAM- 4GB
- CPU- Intel Dual Core/AMD processor
- Storage- 2GB
- Connectivity- USB & Bluetooth
- Resolution- At least 1024 x 768
For Mac
- Operating system- macOS 11 or latest
- RAM- 4GB
- Storage- 2GB
- Connectivity options- USB & Bluetooth
- Resolution- At least 1024 x 768 px
Finally, you can move ahead with the Cricut setup on computer using a wired or wireless connection.
How to Connect Your Cricut to Your Computer Using Bluetooth?
When you’re ready with your Cricut machine and a computer, you can connect both of them together via Bluetooth connection. As a wireless connection is convenient, you can use it to create your projects seamlessly. So, without due, let’s move forward with the steps.
Windows
All the Windows users must follow the steps given below to get started with connecting their Cricut machine to it via Bluetooth connection. Let’s learn how to connect your Cricut to your computer via Bluetooth.
- To start, head to the Settings option and hit the Devices option.
- Then, verify if your computer has a Bluetooth feature ON.
- In the next step, you have to click the Add Bluetooth or other device option.
- After that, hit the Bluetooth option and choose your machine.
- Now, enter your four-digit numbers to get along with the procedure and click on the Connect button.
- Next, you’ll see your devices paired with each other.
This is how you can connect your Cricut product to a Windows computer via Bluetooth and start your crafting journey.
Mac
As a Mac user, you should follow the steps given below on how to connect your Cricut to your computer via Bluetooth. Let’s check the steps here.
- In the first step, go to the Apple menu on your Mac.
- After that, hit the System Preferences option.
- Now, locate the Bluetooth option and check if it is ON.
- Next, select your Cricut model from the list.
Finally, you’ll pair your Cricut machine with your Mac computer. Once both of your devices are paired, you’re ready to utilize your machine for crafting.
How to Setup Cricut Machine on a Computer (Windows/Mac)?
Here are the final steps to setup your Cricut product on your computer. Check the steps, and get started with setup.
- To start, make sure that the Bluetooth connection is finally established.
- Then, navigate to design.cricut.com/setup on an internet browser.
- Now, you’ll need to download and install the Design Space software.
- Next, continue with the on-screen directions to sign in to your Cricut account.
- After that, you’ll finish the Cricut setup on your computer.
This is how you’ll setup a Cricut machine on your computer, like Windows and Mac. Finally, now you know how to connect your Cricut to your computer.
FAQs
Can I Use Cricut With Any Device?
Yes, you can use your Cricut machine with all devices except for Chromebooks. You can connect your Cricut to a Windows and Mac computer, as well as mobile devices such as Android and iOS. So, you have a huge list of ways to use your machine with a device. However, you must ensure that your device is compatible with the Cricut Design Space app.
How to Connect My Cricut to My Phone?
To connect your Cricut product to an Android phone, follow these steps:
- To start, ensure that your machine is about 10-15 feet away from your device.
- Then, open the Settings option on your screen.
- After that, hit the Bluetooth option and turn it ON.
- After turning on the Bluetooth, your device will show you all the available devices.
- Now, choose your Bluetooth device name and allow the pairing.
- When your window asks you for a PIN, type “0000” and hit the Done option.
- Next, you’ll see your machine paired under the Paired Devices.
What Are the System Requirements for Connecting Cricut to Phone?
If you are using a phone with your Cricut, check these minimum system requirements.
For Android
- Operating system- Android 10 or latest
- Broadband internet connection
- Only mobiles and tablets are compatible.
- Chromebooks are not supported.
For iOS
- Operating system- iOS or the latest
For more information visit: www.cricut.com/setup login
