• Catalogue page
    Keith05/02/2024 at 18:48 0 comments
    SCPC286 80286 PC-AT PS/2-Compatible CPU
    The SCPC286 is a highly integrated, high performance 80286-based STEbus CPU, providing all the standard functions of an AT or PS 72-compatible computer.
    SCPC286 is an exceptionally powerful vehicle for implementing control and data acquisition systems. Its STEbus interface overcomes all of the I/O and expansion problems inherent with using standard PCs in an industrial environment.
    On-board is an 80286 CPU running at 16- or 12-MHz, an 80287 co-processor socket (80287 not supplied as standard), up to 1 Mbyte of Dynamic RAM, up to 64 Kbytes EPROM and a battery-backed real-time clock. An AT-compatible keyboard, PS/2 mouse port and floppy disk interface (supporting two standard or high-density 3.5" or 5.25" drives), makes connection to standard PC equipment easy.
    Designed to run PC-DOS or MS-DOS, the board is supplied fitted with a BIOS EPROM supporting shadow RAM, and with built-in fast hard disk BIOS supporting the Arcom SCSI STEbus interface board.
    Expansion through the bus allows users to easily create powerful systems with high performance graphics, ROM disks, RAM disks, I/O and networking connection options. STEbus Interface: STEbus permanent master for single processor applications or as a potential master (using an external arbiter) in multiprocessor systems. Power consumption: Typ 1.1A @ 5V (12MHz).
    Ordering Information
    SCPC286
    SCPC286-12		12MHz CPU with 512Kb DRAM
    SCPC286-121		12MHz CPU with 1Mb DRAM
    SCPC286-16		16MHz CPU with 512Kb DRAM
    SCPC286-161		16MHz CPU with 1Mb DRAM
    Features
    • 16-MHz or 12-MHz 80286 CPU
    • Up to 1Mb DRAM
    • Up to 64Kb EPROM
    • 80287 socket
    • Keyboard interface
    • PS/2 mouse port
    • Floppy disk interface
    • Loudspeaker output
    • Battery-backed real-time clock
    • STEbus interface
    ROM/RAM
    Silicon disk support for ROM-based PC systems
