This is Amazon's Alexa running on a Raspberry Pi Zero built into a mid-century modern intercom for your desk.
View all 6 components
Plug your devices into your Pi, image your SD card with the latest Rasbian, set it up on WiFi, and get it's IP address, we'll need this in a bit. There are many good guides on how to do this including; https://www.raspberrypi.org/help/noobs-setup/ and https://learn.adafruit.com/adafruits-raspberry-pi-lesson-3-network-setup/finding-your-pis-ip-address.
Now that you have your IP we will connect to your PI so we can download Novaspirit's GitHub repository. There are a few options so pick one that works for you. Either through Putty and SSH to your IP https://www.raspberrypi.org/documentation/remote-access/ssh/windows.md, console cable https://learn.adafruit.com/adafruits-raspberry-pi-lesson-5-using-a-console-cable/overview, or by plugging in a mouse, keyboard, and monitor.
Once connected install Git through apt-get with;
sudo apt-get install git
View all 11 instructions
undefined
ollyoid
Yes, delete it Cancel
You are about to report the project "Retro Echo - Pi Zero Assistant", please tell us the reason.
