Simple switch to control Philips Hue lights using Arduino Uno and ESP8266 module
A cool feature would be to add a second rotary encoder that changes the colour of lamps (if supported). Personally I'd like to use a linear encoder for the dimming function.
The github code refers to a file called encoder.h. Can you share please.
https://github.com/PaulStoffregen/Encoder
Dixon Selvan
jesuanlazarte
Electroniclovers123
akarshagarwal98
Yes, delete it Cancel
You are about to report the project "Philips Hue Switch with Arduino and ESP8266", please tell us the reason.
