Hot Tub Control with Open-Source Hardware
Uses the AC400 industrial-grade Arduino-compatible as a simple hardware control system demo. Controls chlorine, heat, lighting, etc.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This is a simple industrial control system based on the OSH "AC400" board from ACCX Products. This is an open-source electronics venture from 23b Hackerspace, originally developed for RFID access control use. The project is written in Arduino Wiring code, and can optionally be fitted up with a Raspberry Pi for web automation.
