This Tiny Joypad "Megazoid Variant" project is now complete. If anybody has any questions - ask away. Many thanks to the kind people that helped out
This might be a nice platform for people who like to write ATtiny85 games. Having the option of sound, screen rotation, and a joystick does give you a bit more flexibility over projects such as Attiny Arcade (although Tiny Joypad is a harder build).
More Tiny Joypad games, info and designs can be found on Daniel Champagne site : https://www.tinyjoypad.com
Slight code changes are needed for PacMan and Tiny Arkanoid for them to work on my version of Tiny Joypad (or just use the files in the Tiny_Joypad_Variant-Games-master.zip )
PacMan - Change
if ((analogRead(A3)>=750)&&(analogRead(A3)<950)) {Sprite[0].DirectionH=1;}
else if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {Sprite[0].DirectionH=0;}
To
if ((analogRead(A3)>=750)&&(analogRead(A3)<950)) {Sprite[0].DirectionH=0;}
else if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {Sprite[0].DirectionH=1;}
Tiny Arkanoid - Change
if ((analogRead(A3)>=750)&&(analogRead(A3)<850)) {if (VARIABLE.TrackBaryDecal<7) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)<44){ VARIABLE.TrackBaryDecal++;}}else{VARIABLE.TrackBaryDecal=0;VARIABLE.TrackBary++;}}
if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {if (VARIABLE.TrackBaryDecal>0) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)>4){ VARIABLE.TrackBaryDecal--;}}else{VARIABLE.TrackBaryDecal=7;VARIABLE.TrackBary--;}}
To
if ((analogRead(A3)>=750)&&(analogRead(A3)<850)) {if (VARIABLE.TrackBaryDecal>0) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)>4){ VARIABLE.TrackBaryDecal--;}}else{VARIABLE.TrackBaryDecal=7;VARIABLE.TrackBary--;}} if ((analogRead(A3)>500)&&(analogRead(A3)<750)) {if (VARIABLE.TrackBaryDecal<7) {if (VARIABLE.TrackBaryDecal+(VARIABLE.TrackBary*8)<44){ VARIABLE.TrackBaryDecal++;}}else{VARIABLE.TrackBaryDecal=0;VARIABLE.TrackBary++;}}
* Don't forget when you program the cartridges, that Pin's 1 and 2 are swapped around on the Pacman and Tiny Arkanoid PCB's.
Thanks for sharing dude you did an awesome as a game enthusiast myself I really loved your idea if anyone wants to look for awesome video games checkout:
https://nullsbrawls.com.tr/
