Nixie Thermometer Hygrometer - Shield for Arduino
Use your Arduino and build Nixie Clock, Thermometer and Hygrometer. Beautifully made housing and easy to operate.
Project can be found on crowdfunding campaign: https://igg.me/at/nixieshield
Parameters & Components
  • Perfect quality housing (color: black, red, blue), laser-cut and engraved
  • Housing dimensions: 60 x 80 x 158 mm (~2.4" x 3.1" x 6.2")
  • High quality connectors & pin headers (only these components require soldering)
  • Nixie power supply module 170V
  • Extremely accurate RTC module - DS3231
  • Precise and accurate temperature & humidity sensor DHT22
  • Shield requires +12V power supply (Arduino Vin power supply connector)
  • Compatible with Arduino UNO
    How does this work?
    What's Inside
    Replaceable Nixie Tubes
    Three device options are possible:
    • Nixie Clock - 4 x IN-12B Nixie Tubes
    • Fahrenheit - Nixie Thermometer/Hygrometer - 3 x IN-12B + IN-15B Nixie Tubes
    • Cesius - Nixie Thermometer/Hygrometer - 3 x IN-12B + IN-15A Nixie Tubes
    Easy Arduino Coding
    Datasheet and examples codes can be found in the project repository
    Code is very simple and uses only two Arduino libraries: for real time clock DS3231 and second for temperature and humidity sensor DHT22. Nixie tubes are controlled by HV5812 high voltage drivers by using only 3 arduino pins. You can modify the code according to your own ideas.
    Project repository
    // Nixie Clock Thermometer Hygrometer Arduino Shield by Marcin Saj https://nixietester.com
    // https://github.com/marcinsaj/Nixie-Clock-Thermometer-Hygrometer-Arduino-Shield
    // Driving Nixie Tubes Example
    // This example demonstrates how to display digits on nixie tubes. Settings are sent via a serial monitor.
    // The control is carried out using two HV5812 drivers: http://ww1.microchip.com/downloads/en/DeviceDoc/20005629A.pdf
    // The HV5812 is a 20-channel serial-input display driver. It combines a 20-bit CMOS shift register,
    // data latches and control circuitry with high-voltage MOSFET outputs.
    // Hardware:
    // Arduino Uno & Nixie Clock Thermometer Hygrometer Arduino Shield
    // Schematic: http://bit.ly/Nixie-Clock-Thermometer-Hygrometer-Arduino-Shield-Schematic
    // EN        connected to Arduino pin A2
    // DIN       connected to Arduino pin 12
    // CLK       connected to Arduino pin A1
    // STR       connected to Arduino pin A0
    // DATA      connected to Arduino pin A3
    // DOT       connected to Arduino pin 4
    // RTC SDA   connected to Arduino pin SDA
    // RTC SCL   connected to Arduino pin SCL
    #define EN    A2     // Nixie Power Supply Module: "0" - ON, "1" - OFF
    #define DIN   12     // HV5812 serial data input
    #define CLK   A1     // HV5812 data shift register clock input
    #define STR   A0     // HV5812 output enable input
    #define DOT   4      // Nixie tube dot symbol
    // Bit array for 4 nixie tubes, 10 bits for each tube
    boolean nixieDisplayArray[40];
    // Assignment of the connected cathodes to the position in the 40 bit array
    // Each cathode of nixie tubes is connected to the corresponding output of the HV5812 driver
    int nixie1[]={26, 27, 28, 29, 20, 21, 22, 23, 24, 25};
               //  0,  1,  2,  3,  4,  5,  6,  7,  8,  9
    int nixie2[]={33, 32, 31, 30, 39, 38, 37, 36, 35, 34};
    int nixie3[]={ 8,  7,  6,  5,  4,  3,  2,  1,  0,  9};
    int nixie4[]={11, 12, 13, 14, 15, 16, 17, 18, 19, 10};
    int digit1, digit2, digit3, digit4;
    void setup()
        Serial.begin(9600);
        // Initialize connected pins as an output
        pinMode(EN, OUTPUT);
        digitalWrite(EN, HIGH);     // Turn off NPS - Nixie Power Supply Module
        pinMode(CLK, OUTPUT);       // Nixie driver data shift register clock input
        digitalWrite(CLK, LOW);
        pinMode(DIN, OUTPUT);       // Nixie driver serial data input
        digitalWrite(DIN, LOW);
        pinMode(STR, OUTPUT);       // Nixie driver output enable input
        digitalWrite(STR, LOW);
        pinMode(DOT, OUTPUT);       // Nixie tube dot
        digitalWrite(DOT, HIGH);    // Turn on nixie dot
        delay(3000);
        digitalWrite(EN, LOW);      // Turn on NPS - Nixie Power Supply Module
    void loop()
        Serial.print("Enter a number from range 0-9999: ");
        // Wait...
    Adobe Portable Document Format - 1.91 MB - 03/30/2019 at 13:37
    Preview
    Download
    Adobe Portable Document Format - 1.05 MB - 03/30/2019 at 13:37
    Preview
    Download
    View project log
