With FlexPCB, custom-designed LED strip is feasible. Here is one with 5mm through-hole LEDs. It can be put on to my party hat.
The PCB is back.
JPEG Image - 268.80 kB - 06/06/2019 at 17:51
I would recommend using Surface mount LED's. The Though hole LED's should be fairly simple to solder though.
Stanislas Bertrand
matt thurstan
Jacob.R.Jennings
Philip Cox
Yes, delete it Cancel
You are about to report the project "LED strip design with FlexPCB ", please tell us the reason.
