mini (Pi)QWERTY USB keyboard II.
USB hid keyboard ... etc. for Raspberry PI is back in black, more beauty with more features ;)
Starting from
$18.99
bobricius has 2094 orders / 92reviews
Ships from Slovakia
NEW KEYBOARDS Almost ready > Enhanced to 49 keys = 7x7 Matrix
ino - 8.90 kB - 04/17/2021 at 21:08
Download
black36v2.UF2
Compiled ready to use drag&drop firmware
uf2 - 512.00 kB - 04/17/2021 at 21:06
Download
FirmwareKey49FixQcoma.UF2
Download
ino - 9.42 kB - 02/22/2021 at 00:19
Download
bootloader-ArmaBOOT.bin
UF2 bootloader for SAMD21E18
octet-stream - 8.00 kB - 11/27/2020 at 08:25
Download
View all 8 files
  • 1
    Setup Arduino IDE and bootloader
    I am using Atmel-ICE, I have no idea about another way how to program bootloader now!
    Arduino > Preferences : Additional boards manager URLs ADD https://www.mattairtech.com/software/arduino/beta/package_MattairTech_index.json
    Arduino > Tools > Boards manager : MattairTech MT-D21E (rev B)
    Arduino > Tools > Clock > Source : INTERNAL_OSCILLATOR
    Arduino >Tools > Serial config : ONE_UART_ONE_WIRE_TWO_SPI
    Connect GND, VCC, SWC, SWD, Reset to ATMEL-ICE
    Arduino > Tools > Programmer : ATMEL-ICE Arduino > Tools > BURN BOOTLOADER
    • Now you can upload sketches with USB
    Or second option:
    From Atmel Studio write special ARMABOT.bin then you can easy upload firmwares drag&drop
View all instructions
Chris wrote 12/09/2021 at 19:14 point
Do you have the PCB/Schematic for the new 49-key keyboard? If so, could you please post them -- would greatly appreciate it :)
Leah wrote 04/06/2021 at 17:14 point
Has anyone designed a case for this little beauty?
Kayla Theil wrote 02/11/2021 at 09:41 point
I have the earlier version of this keyboard (with just the two SHIFT/FN LEDs) and would like to modify the firmware. Where can I find the source code of the preinstalled firmware?
Kayla Theil wrote 02/12/2021 at 13:18 point
Oh I didn't think that was the same as the board design looks very different ^^. I'll try it out with that code, thanks
Any idea when the next version will be available for sale? I really like the new layout on that one (the current one has a few problems if you want to control a terminal-based system...)
pyke.engelen wrote 01/09/2021 at 10:01 point
that looks fantastic
but the images don't match the files, why?
bobricius wrote 01/09/2021 at 17:55 point
evolution
ABrugsch wrote 10/20/2020 at 07:47 point
looking forward to the details of this one. I like the PTH for the buttons instead of NPTH on the 4 row one. it looks great with black and ENIG!
bobricius wrote 10/20/2020 at 21:20 point
Thanks. 3 years ago I not know possibility to make 4mm holes (I draw in mill layer) Eagle have standard maximum 3mm holes.... but I learning every day ...
[deleted]
bobricius wrote 10/19/2020 at 19:50 point
This is because "I can " :P
bobricius wrote 10/19/2020 at 21:01 point
I designed it because there is no WIRED supersmall keyboard for RPI, almost all are wirelesss or BT
Gabriel wrote 10/19/2020 at 12:08 point
beautiful work, its just gorgeous!
