One-Shot using 555
A one-shot timer based on the 555. It features: optional voltage regulator, adjustable output, pamp output buffer.
0 followers
# Overall description
The design is a one-hot circuit based on the 555 timer. I needed it at work for two different uses, so I made it somewhat flexible.
# Power
You may choose to use the LDO from Micrel, or you may choose to drop it and use a 0R resistor instead. In both cases, it is possible to use a diode to protect the circuit form wrong polarity on the input power. The LDO solution offers adjustable output voltage.
# Input
The input is made to be used with a push-button, but I'm sure most of you can figure out other ways to trig the timer. It requires a negative edge.
# Output
The output is attenuated using a potentiometer and some optional resistors. This gives a good control of the output voltage. If very good control of output voltage is required, use of an LDO is recommended. The attenuated pulse is buffered in an unity-gain opamp circuit, and finally, the output signal passes through a resistor and capacitor that can be used as current and/or DC limiting dev
sim1.asc
LTspice file if you feel like simulating the circuit (without the regulator). It's made on a Mac, but I believe it should work on any LTspice.
plain - 3.33 kB - 01/27/2021 at 07:48
Download
BOM_PartType-OneShot1.csv
Bill Of Materials. Most parts have compatible parts from other vendors.
Comma-Separated Values - 1.41 kB - 01/27/2021 at 07:26
Download
OneShot1.PDF
Schematic and PCB
Adobe Portable Document Format - 356.50 kB - 01/27/2021 at 07:23
Preview
Download
