mcurses library ports
This project is a migration of mcurses library from Arduino to Netburner's MODM7AE70 and to STM32F407ZG
0 followers
mcurses is an embedded version of the ncurses library available on github here:
https://github.com/ChrisMicro/mcurses
Makefile is provided to compile on the command line, or you can use codeblocks.
This will generate a static library usable for your own projects.
An example project is provided which shows how to link with this library.
Decompress the library and the example project in the same folder, in which you created an include and lib folders.
Make and install the library first:
Change to the 'mcurses' folder, run 'make' and 'make install'
Change to 'test-mcurses' and run 'make'
Binaries should be ready for uploading to the Netburner.
SMT32F4-test-mcurses.tar.bz2
An example for STM32F4 that links the static mcurses library. it also uses the redirect target. See How to Use printf on STM32 https://shawnhymel.com/1873/how-to-use-printf-on-stm32/ The name when unzipped will be Z80-softmicro. For now, I tested mcurses with it.
x-bzip - 6.15 MB - 03/07/2021 at 15:59
Download
STM32F4-mcurses.tar.bz2
The mcurses library itself, with small modifs to compile for STM32F4xx
x-bzip - 3.20 MB - 03/07/2021 at 15:59
Download
mcurses.tar.bz2
The mcurses library itself, with small modifs to compile for Netburner.
x-bzip - 477.67 kB - 03/06/2021 at 13:56
Download
An example that links the static mcurses library
x-bzip - 2.32 kB - 03/06/2021 at 13:56
Download
