CH55xG Tiny
Tiny Breakout Board for CH551G/CH552G/CH554G 8-bit MCUs
CH55x Series are 8051 MCUs with USB interface. They are cheap (cost less than $0.5). They can be programmed by USB without any programmer. They can be developed with Arduino. This breakout board for CH55xG series fans out all IOs within a compact size. It can be used as a development board or be embedded into a device directly.
About This Board
  • Breaks out all IOs within a compact size (2.5x1.6cm)
  • Breadboard-friendly pitch
  • One-sided components arrangement simplifies surface mounting
The layout files are available in KiCAD format at linked Github repository.
Developing with Arduino-like API
You can try this board with ch55xduino. The marks of pins on this board adopts the same scheme as the one used in ch55xduino, i.e. Mark = PortNumber*10+PinNumber .
  • 1 × CH552G Or CH551G, CH554G
  • 3 × 0603 0.1uF MLCC
  • 1 × 0603 10k Resistor
  • 1 × 0603 4.7k Resistor
  • 2 × 2x3mm Button switch
View all 7 components
View project log
