Meshtastic Mesh Device Station Edition G1
The Station Edition series is a compact Lora device with 3W high power PA.
Starting from
$109.00
neilhao has 499 orders / 2reviews
Ships from China
The Station Edition series is a compact Lora device with 3W high power PA (Maximum TX Power: 35dBm@915MHz or 868MHz for Station G1 Edition), Rugged SMA Antenna Socket, rich external IO interface, wide input voltage range (8VDC-20VDC). This series aims to provide the best RF performance in all series with credit card size and rugged construction. Fixed-location base stations and vehicle-mounted base stations are typical application scenarios for this series.
For the firmware, Meshtastic firmware 1.2.65 is preinstalled. Meshtastic Mesh Device Station Edition G1 is expected to be merged into the official meshtastic repository on Github starting from firmware 1.3.
Overview
Meshtastic can send off-grid message using inexpensive hardware to create your personal mesh.
The Station Edition series is a compact Lora device with high power PA (Maximum TX Power: 35dBm@915MHz or 868MHz for Station G1 Edition), Rugged SMA Antenna Socket, rich external IO interface, wide input voltage range (8VDC-20VDC). This series aims to provide the best RF performance in all series with credit card size and rugged construction. Fixed-location base stations and vehicle-mounted base stations are typical application scenarios for this series.
Dimension
Item Description
Size 10cm*5.8cm*2.1cm
Color Black
Weight~80g
Typical RF Performance
Item Description
Lora Operation Frequency US915MHz and EU868MHz
Lora RF Max Output Power35 dBm @ US915MHz (Station Edition G1)
Lora Power Amplifier Gain 21.5dB @ US915MHz (Station Edition G1)
Lora Power Amplifier P1dB Point 34.5 dBm @ US915MHz (Station Edition G1)
Lora Power Amplifier Noise Figure 0.96dB @ US915MHz (Station Edition G1)
VSWR of Lora Stock Antenna< =2 @ 915 MHz
Typical Application Scenarios
Station Edition could be powered by either USB Type C (PD Protocol with minimum 9V2A is required, 15V2A is recommended due to the requirements of 12V Battery Docker) or 2Pins Socket (Pitch=2.5mm, 8VDC-20VDC, 2A minimum).
Wide voltage input makes the Station Edition ideal as an vehicle-mounted base station and powered directly from the in-vehicle 12V system. The USB Type C power input allows the device to be easily powered by a USB Type C adapter which supports the PD protocol.
Ability to increase transmit power makes it possible to balance communication distance and communication speed. For low power meshtastic devices, usually necessary to set the modem to Long/Slow to obtain the required communication distance, but when using this setting, the communication speed will be very slow, and the continuous sending of messages will also cause timeouts. By increasing the transmit power, we can set the modem to Long/Fast or even Medium/Fast to get a similar experience to Internet-based instant messaging software.
More information about modem setting: https://meshtastic.org/docs/settings/channel#modem_config
Hardware
Schematics
Schematics for 12V Battery Dockermeshtastic_mesh_device_station_edition_12v_battery_docker_28_jul_2022.pdfVersion: 28 Jul 2022
Schematics for Station Edition G1meshtastic_mesh_device_station_edition_12_jun_2022.pdfVersion: 12 Jun 2022
PCB (Station Edition G1)
No. Description
1 ESP32 WROOM
2 Semtech SX1262 Lora Transceiver
3 Lora Power Amplifier
4 RF Switch
5 SMA Connector for Lora Antenna
6 USB Type C Socket
7 CH9102F USB to UART Bridge
8 Power Input Socket (8VDC-20VDC), 1*2P, Pitch=2.5mm
9 7.5V DCDC
10 3.3V DCDC
11 GPS and Notification Extension Socket, 1*5P, Pitch=1.5mm
12 IO Extension Socket, 1*10P, Pitch=1.5mm
13 LV (Low Voltage) LED Indicator
14 HV (High Voltage) LED Indicator
15 1.3 Inch OLED Screen
16 User Button
Power Status
LV LED (Red) HV LED (Green) Description
ON OFF 3.3V DCDC is working normally, but 7.5V DCDC is not working. Generally, this status indicates the device is powered up by using USB2.0/3.0 which does not support 9V USB Type C PD protocol. For this status, everything should work normally, except the Lora PA. The firmware can be flashed into the device through Type C Port in this status.
ON ON Both 3.3V DCDC and 7.5V DCDC are working normally. Generally, this status indicates the device is powered up by 9V USB Type C PD protocol. For...
View project log
