24 channel 1D array
A project log for Phased array sonar
DIY sonar with 24 channel receiver and active transmitter with 1 (up to 4) channel
null1null1 11/17/2022 at 21:020 Comments
Assembly and sound testing my 24 channel array.
Element spacing has been changed to 1.01cm, which allows me to use pulse frequencies 18kHz-22kHz. This should give better range resolution, narrower beams, if my speakers can handle the frequencies.
Going ultrasonic, around 40kHz, would require me to reduce element spacing. With the current microphones, thats not possible.
First test:
Anything above 2m, are reflections i.e. multi-path. To the right, at around 1m, there is a chair and a wall. There is a lot of "tuning" ahead. Image seems a bit noisy. Some of the noise are coming from side lopes, some are multi path.
