4ch hydrophone array
A project log for Phased array sonar
DIY sonar with 24 channel receiver and active transmitter with 1 (up to 4) channel
null1null1 11/21/2022 at 23:050 Comments
I received 4x hydrophones for an upcoming experiment. I plan on aligning them with element spacing of around 15cm, bring the frequency down to 1-5kHz. It wont have a transmitter making it listening device only.
2 hydrophones
Hydrophones are going to be used with experiments of detection where underwater sounds are coming from.
Beam pattern would look like
Frequencies below 5kHz and above 2kHz would give a reasonable direction ability. Whale songs is in this range.
So when weather gets better, I will take my EVO8 (channel sampler), my laptop, on a field trip to the local harbour.
