Final Testing
A project log for MacroPad With Tile Buttons
As a quick follow-up to my “A Tile Based MacroPad” I present an alternative.
michael-gardiMichael Gardi 10/20/2023 at 19:240 Comments
I created a Calibrate_MacroPad_2 sketch that took into consideration the small differences between this project and the A Tile Based MacroPad project. These small differences resulted from two wiring changes I made:
  1. When I started testing I realized that I had switched a couple of the pin assignments between the pro Micro and the multiplexer (the S2 and S3 selector bits). Rather that rewire I just switched the pin assignments in the sketch.
  2. I wired the sensors differently for this project to make the wiring neater. This required that the mappings between the buttons and the sensors need to change.
I ran the calibration without issues and copied the midValues and calValues tables produced to a new MacroPad_2 sketch. Then I made the same pin and sensor assignment changes that I did to the Calibrate_MacroPad_2 sketch.
And that was it. The new MacroPad 2 was up and running.
I have updated GitHub with the new sketches and the additional models required to make a MacroPad 2.
