XAC_onehand_pico
One hand controller for Xbox console using an Xbox Adaptive Controller and 3 Raspberry Pi Picos
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The xac_onehand_pico project connects a USB flight stick such as a Logitech Extreme 3D Pro to both USB ports on an Xbox Adaptive Controller (XAC). This allows one handed gamers to play two joystick games. The Logitech Extreme 3D Pro, the Logitech X52 H.O.T.A.S., and the Thrustmaster T.16000M FCS joysticks are supported. No soldering is needed.
This project was inspired by an older XAC joystick splitter project.
Note: This project does not use the Pico-PIO-USB library because the Pico-PIO-USB library does not work for the Thrustmaster flight stick. See the related project https://github.com/touchgadget/xac_onehand for a simpler build but no support for the Thrustmaster flight stick.
For source code see https://github.com/touchgadget/xac_onehand_pico.
