ESP32_USB_Host_HID
Port of the ESP-IDF USB host HID code to the Arduino IDE with minimal changes. This is an Arduino library with examples.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Port of the ESP-IDF USB host HID example to the Arduino IDE with minimal changes. This is an Arduino library so install it in your Arduino library directory. The easiest way to do this is to download this repo as ZIP file. Then use the IDE "Add ZIP library" option to install this code into the correct directory.
Tested using Arduino IDE 1.8.19 and Espressif ESP32-BOX-S3-3 with USB host dock. The code is available at https://github.com/esp32beans/ESP32_USB_Host_HID
