The Quub
Open-source microcontroller system based on an Raspberry Pi Pico core processor and stackable interface boards
robrob
Public Chat
Open-source microcontroller system based on a Raspberry Pi Pico core processor and stackable interface boards
QUUB is an open-source, micro controller system based on a core processor, addressable daughter boards, and remote IO modules. It is a general-purpose embedded microprocessor system, the form factor is based on a main MCU board and multiple stacked IO boards called "stackables". It can therefore accommodate designs from the simplest flashing-LED project to a complex multi-processor robot controller.
The QUUB system has the following features.
  • The core processor board is an Raspberry Pi Pico module, this is a dual core 32-bit Cortex M0+ processor running at 133MHz.
  • Small form factor, nominally 100 x 75mm (4 x 3 inches).
  • A unique method of attaching four "sides" (vertical PCBs). These sides make the QUUB design "self enclosing", no need for a box.
  • Up to 16 addressable daughter boards (stackables) can be stacked above or below the core processor.
  • Up to 16 addressable devices on each stackable.
  • Each stackable has a ID EEPROM that defines its IO capabilities for the MCU.
  • Up to 256 vectored interrupts from these stackable modules
  • Two RS485 drivers and onboard address switch allow up to 16 QUUB boards to be connected to the QUUBnet.
  • An optional "mezzanine" expansion module with an 18-way interface, useful for small addons such as an SD card socket.
  • 36+3+7-way "stackplane" using stackable headers.
  • The stackplane has provision for all power signals, 2x I2C, SPI, 2x UART, 2x analogue in, up to 16 digital IO, four user-defined signals, and addressing of daughter boards.
  • All 16 daughter boards can be addressed and can therefore share the same system IO lines.
  • On-board solid state relay to drive an external device such as an alarm or light.
  • On-board piezo buzzer.
  • A PiicoDEV (STEMMA-QT/QWIIC) header.
  • Two front-panel accessible pushbuttons that are used for reset and a user input
  • 7-20 volt polarity-protected VIN.
  • One switched power signal that can be used by the MCU to shut down peripherals such as a GPS or wireless transmitter.
  • Four mounting holes suitable for an M3 bolt or similar-sized screw.
  • One-digit 7-segment LED display for a heartbeat or error code display.
If you need a system with over 20 analogue inputs, or maybe 30 serial ports, or more than 200 digital IO connections, no problems, QUUB can do that and more.
Stackplane (backplane for the QUUB stack) The stackplane consists of three headers of 36, 7 and 3 connections. With the vast array of I2C and SPI peripheral IO chips now available it makes sense for larger and more complex applications to have a backplane with just a few signals that communicate with slave devices using one of these popular serial interfaces. However for tinkering or simpler applications the QUUB can be used like any of the other development boards available.
There are four user-defined signals on the stackplane, these signals pass up the entire stack and can be used by any stackable for whatever purposes. One example would be a power supply stackable sitting at the bottom of the stack that needs an ON/OFF switch and a power indicator LED at the top of the stack.
Side panels (sides) Provision is made to solder small PCBs at right angles to the main PCB. These can be used to enclose the board so a box is not normally required. If all stackables implement these side panels the QUUB stack becomes fully enclosed on the bottom and sides. This leaves the top.
Lids Lids are special stackables that are only used on the top of the stack. They are 3mm larger than the standard stackable size so they cover the stackable sides below them. Lids can be blank and used simply to fully enclose the stack, or they can also have active circuitry, such as an LCD display and some switches to provide a simple user interface to the stack's application.
Bases A base is not normally required as the MCU board has no components on the solder side of the board. However the MCU may not be the lowest stackable and the one that is may have through-hole components. In this case a base board may be required to isolate the electronics from...
Latest PCBs for the CPU.
JPEG Image - 1.69 MB - 03/16/2022 at 23:29
Preview
Download
Schematic.pdf
Schematic design as at 13 Sep 2021
Adobe Portable Document Format - 108.72 kB - 09/13/2021 at 10:16
Preview
Download
This is the new design. Where as the original only had a single solder-on side this has four, all of which can house electronics and/or be connectors for IO interfaces.
JPEG Image - 391.94 kB - 01/06/2021 at 20:44
Preview
Download
  • The latest PCB
    rob6 days ago 0 comments
    Mission creep has set in and I've added a lot of features. Here is a 3D render of the latest version of the main PCB.
  • Slight update
    rob02/25/2024 at 21:56 0 comments
    Almost as soon as I received the last PCBs I had a few ideas for some changes. So I'll be getting new ones made and won't be using the last ones. They cost almost nothing to make these days so might as well get it as right as possible eh?
  • Yet another processor and PCB design
    rob02/20/2024 at 05:22 0 comments
    This project started about 10 years ago and has had more starts than Phar Lap (Aussie joke). Yet more processor PCBs made recently. The core processor has been changed to a Raspberry Pi Pico, partly because it has castellated pads so it can be soldered directly to the QUUB board, and partly because I think that there is a much larger following and body of work out there for that particular processor.
    Here are five of them stacked, giving some idea of where the QUUB name came from :grin: Of course one would not stack five MCU boards, I just wanted to check the mechanical aspects of the idea.
  • New PCBs received.
    rob03/16/2022 at 23:39 0 comments
    The new CPU boards are here, I already have some changes in mind so I may not even test these one, we'll see.
  • A quick video showing most of the QUUB features.
    rob10/14/2021 at 21:38 0 comments
  • PCB v2 is almost ready for fab
    rob09/13/2021 at 07:07 0 comments
    The PCB v1 has been in use for a while now and some support code has been written to remap a few of the default Adafruit pins to get a second UART etc.
    During the course of this I had many new ideas and have modified the PCB substantially. It's almost ready to be fabbed as v2 now, here's a 3D render of the new look.
    NOTE: Circuit boards called "walls" can be soldered at right angles to the main PCB on the four edges, these have access to all the backplane signals so can have active electronics and connecters to facilitate IO, or just be blank to form the sides of a box. These walls are designated as per the cardinal points of a compass, N, E, W, and S.
    With all four walls in place and the addition of a top PCB the design is essentially "self enclosing".
    The "stackplane" is now three Arduino-style socket strips, one is 22-way with most of the logic signals and two are 3-way that mostly carry power.
    The expansion bus has been extended to include most of the backplane signals. The expansion module now sits at the same height as the Adafruilt CPU module. Normally this expansion module would be used for small functions that don't justify an entire stackable daughter board, such as an RTC or micro SD card. It could also be used for IO like a serial port or more STEMMA-QT/QWIIC interfaces as it has some access to the west and east walls and even the south wall if it is designed in an L shape.
    There is now hardware decoding for six slave select signals, one for each wall, one for the expansion module, and another for the backplane. Thus up to six devices can share signals such as the SPI interface. Alternatively up to 16 stackable and addressable boards are allowed for and each such board can provide a vectored interrupt with a protocol for this being largely defined.
    Two STEMMA-QT/QWIIC connecters have been added, this is fast becoming a standard so it makes sense to include them. I always planned to have a quad buffered interface for this and still will, but these two connecters allow the use of STEMMA-QT/QWIIC modules right off the bat.
    Another addition is dedicated pins on the debug header, these can be used as scope triggers or for other high-speed measuring. Also internal data variables can be bit banged out these pins and read on a scope. Code has been written to do this. Naturally a standard ICE debugger for an ARM can be used as well and I have plans to design a debug board with some useful features.
    Finally both the debug and expansion headers allow for the direct plugging in of a common 0.91" OLED I2C serial display, either for debugging or general UI purposes.
  • PCB fab is in progress
    rob06/25/2021 at 22:39 0 comments
    The design files have just been uploaded to JLCBPCB, this is the base board to hold the Adafruit CPU module. The tabs on each corner are to locate the side "walls" that can house more circuitry and/or physical IO connectors.
  • A new simpler and more powerful design
    rob01/06/2021 at 20:58 0 comments
    This is the new design. After a few years of inaction I've come up with a modified design that is much simpler and yet more powerful in most ways.
    The original design only had a single solder-on side, this new design has four, all of which can house electronics and/or connectors for IO interfaces.
    Another big change is the processor. Despite the fact that I love their chips and tool chain, after total lack of support from NXP I've gone with an off-the-shelf design in the form of a tiny carrier board with a ATSAMD51 Cortex M4. This is an Adafruit product that has good support and is Arduino ready. Therefore I will spend almost no time debugging the processor electronics and fighting with the development toolchain only to wind up with something that nobody will want to use because it's not "Arduino inside".
    Of course, as the processor is on a carrier board, and the backplane is very generic, a new processor version can be designed at any time and just plugged in.
  • New version being considered
    rob09/09/2019 at 01:00 0 comments
    This project has languished for a long time but I think I will resurrect it.
    The format will change but still be similar in many ways, with stackable boards and solder-on front panels. The main difference is that the new design uses an LPC1549 ARM processor and has built in RS485 networking using a protocol I am designing called R3N (Robust Redundant Ring Network).
    Why bother when you can run Linux and WiFi or Ethernet on a board 1" square these days? I dunno, I just like doing this stuff and I can see uses for it.
  • Boards back from PCBA
    rob09/24/2014 at 21:55 0 comments
View all 12 project logs
rob wrote 03/09/2014 at 22:48 point
PCB design finished for the first core processor board, an ATmega2560 with 512k external SRAM. Getting PCBA quotes for first prototypes soon.
