Schematic and Bread Board Tesing
A project log for NOCTURNAL SOLAR LIGHT BULB
Designed to replace the kerosene lamps with solar-powered ones
open-green-energyOpen Green Energy 03/14/2015 at 14:400 Comments
The output is not a steady DC voltage but a voltage that fluctuates rapidly.In my case the frequency is around
184.5 KHz. The peak to peak voltage is nearly 7.28 V and the average value is around 1.0 to 1.20V.
