• Some of the parts are received :D
    10 days ago • 0 comments
    A pile of parts I ordered finally came in! I now have some design choices to make, such as do I want to just hand wire this or should I make a proper PCB ... then if I do that, should I order it or etch it myself? Decisions Decision....
    Here is a shot of some of the ICs that I am going to be using in the build.
    I know I am a bit old fashioned, but there is just something fun and nostalgic for me when working with through hole components ^^;;
    ~Cheers!
    Jessie
    ThunderSqueak
  • Possible Instruction Set
    17 days ago • 3 comments
    While waiting for components to arrive, I have been doing some late night musing as to what functions I wish to implement into the CPU.
    This is the list so far of opcodes, 0 through 13 (000 to +++), that I have been considering.
    I want to attempt to keep the list down to 14 instructions, and am open to suggestions as to what should be removed from this list and have something more useful added in its place. LD and ST may be simplified to a MOV command freeing up one of the "slots".
    This gives me a bit of a goal while doing the design, making the idea that much more concrete.
    Another decision that has to be made is how many trits wide I want to make the system bus. The current thought is to make it 6, this is mostly due to cost of components on a hobby project :) The first 3 will be used for the opcode, the second set of 3 will be for the address that will be used.
    Now to get back to calculus homework ^^;;
    ~ThunderSqueak
  • Construction of the ALU
    22 days ago • 0 comments
    After doing the presentation at the HaD 10th anniversary convention I have been inspired to finish this project.
    Parts sufficient to construct the ALU have been placed on order, I am going to be working with the vishay DG403 chip, and plan on building it in such a way that I will probably end up with a hybrid ternary/binary cpu.
    I have removed the kleene logic table as it seems to confuse people in that it is more of a philosophical thing as apposed to a pure logic meant for use in a CPU ^^;;
    The logic tables for doing math are as follows,
    The chip in question appears to almost be ideal for the situation,
    In other news, I have been toying with the idea of playing around with magnetic core memory, the final plan will most likely to use a transistor based memory system, however sometimes it is fun to look at older tech.
    More to come after I receive the components and begin a proper build! :D
    Thanks everyone for your support!
    Now back to studying for midterms.... the joys of going back to school :)
    ~ThunderSqueak
