First Laser Test with new firmware.
A project log for OpenExposer
An affordable Arduino controlled multipurpose laser exposing device. Use it for SLA Printers, PCB Exposing, Laser Harp etc.
mario-lukasMario Lukas 01/15/2015 at 15:440 Comments
The new open exposer firmware supports G-Code now. I also wrote some tools to handle g-code files.
The toolchain works as follows:
1. generate a stl file with your favourite cad software
2. sclice the stl to svg with slic3r
3. use the open-exposer slicer to post process the svg file and generate the g-code file
4. send g-code to open exposer with open exposer sender
All tools are written in python. I implemented a small plugin interface for the post processor. With plugins the post processor can be extended to handle different input file formats. By default it supports svg ( slic3r export).
Here is a small video which shows the exposure process with the new firmware.
