windspiel: wind chimes music box
windspiel [ger.] = wind chimes; spiel [ger.] = play.... play... to play a record?
One day last winter I had this stupid idea without a particular reason...
A simple cheap musicbox from ebay, mounting bracket, a plastic sphere for decoration stuff... if combined, these things create a wonderful annoying noise maker that is an absolute killer of concentration.
It plays Elfen Lied - Lilium, at least if the wind is steady. Else it just plays a few notes at once every few minutes.
Material cost is below 10 Eur, should be doable in a few hours.
Michał B. wrote 02/05/2015 at 17:02 point
Does it prevent the spring from overwinding?
rawe wrote 02/06/2015 at 09:45 point
there is no spring in there, just a worm drive which drives the drum.
