Become a member to follow this project and don't miss any updates
The Flux Buggy
An Electric Dune Buggy Capable of Scary Amounts of Torque
0 27 15
Share on twitter   Share on Facebook
This project was created on 05/24/2014 and last updated a month ago.
Description
So, as you know, the Delsolectric (electric Honda Del Sol I made) never got on the road legally. As such, we decided to scrap it. Now we're going to put the guts of a 3000lb electric car into a <1000lb dune buggy. Hello acceleration!!!
Details
So as you may or may not know, the Delsolectric never made it onto the road legally. In fact, we had to scrap it since it was just sitting in my friend's parent's backyard for... a few years.
Anyway, we did keep all the parts. We had wanted to build an electric go kart for a while, but never really had the space. I just moved into a new place, with my very own garage, and we decided it was time to do it.
We found this custom home made dune buggy on Kijiji for $1,500, marked down from $3,000. A guy had it commissioned and it is slick. It had a 13HP Honda engine in it and didn't go that fast, but it was built extremely well. The whole thing is made of 1-1/4" steel tubing, with lubed bearings, shocks, and a fancy aluminum tread plate cover. It was ripe for conversion.
Watch the following video for a brief introduction to the project:
We bought it, sold the engine for $300, and started work. Follow the complete video chronicles here -- and don't forget to subscribe for updates!
Components
  • 1 × 880lb Dune Buggy
  • 1 × General Electric DC Series Wound 36V motor We'll be cranking it up to 11 with 72V!
  • 6 × 12V 140aH Marine Grade Lead Acid Battery These things weigh 67lbs each!
  • 1 × Alltrax 72V 450A Speed Controller Typically used for a golf cart
  • 1 × Custom gearbox Made by hand
  • 1 × Fuzzy Dice For maximum coolness
  • 2 × Heavy Duty Contactors (relays on steroids) From the electric forklift
  • 1 × 10k ohm potentiometer accelerator For the speed controller
Project logs
  • The Gearbox
    a month ago • 0 comments
    Building the gearbox!
  • Battery Mounts
    3 months ago • 0 comments
    Time to start modifying the frame! We picked up a bunch of steel from the local Metal Supermarket (no seriously, that's what it is called!) and designed battery mounts off the side of the buggy.
    These help keep the center of gravity very low to the ground (the batteries weigh almost 500lbs), but do not hang any lower than the current frame (we still want to be able to go off-roading with it). It looks like we'll have to upgrade the suspension too, as the front suspension is completely bottomed out now with the weight of the batteries in the buggy (let alone a driver!).
  • The Shopping Trip
    4 months ago • 0 comments
    After sketching up some ideas, we needed some parts! Off to our favorite hardware store -- Princess Auto.
    Some of our spoils:
    We'll most likely need more, but at least we can start fabricating something now!
View all 4 project logs
